Circuit VL commo - HSVSUX
    Originally posted by Dimi View Post
    Who made the doors, what sort of weight loss?
    Alpha made them, 3.5kgs rear, 4.5kg front (that doesn't include hardware or windows) Massive weight saving. I already have boot and bonnet in fibreglass, about to get front guards done, I've shifted the factory flare up 30mm on the steel fronts, just need to bog it out the right amount and I'll get some moulds done.
      I would have thought a 65 amp alternator might be marginal for a 6 cylinder?
      6 x low impedance injectors @ 5 amps each = 30 amps
      ignition system 8 amps
      2 x fuel pumps 15 amps
      ECU and other miscellaneous electrics 5 amps
      windscreen wipers and demist if it's raining 10 amps
      Total = 68 amps (dodgy guesstimate)
      Might it not be better to have a larger alternator and not have it excited all the time eg. turn it off when over x% throttle?
        I have run the standard 70amp one up until now and have been fine, logging shows 13.3v minimum during races, this one is half the weight.
          I love that switch panel- absolute lightness and has been thought through. Awesome.
            Thanks
              Shell now blasted and painted
              Finally putting the old girl back together
                looks too good to beat up on a track :D
                  Haha, the brother in-law said the same thing. can't wait to 'beat up' the pos, been way too long off the track (3+ years)
                    Anything fancy with rear end ? Watts link ? . I haven't gone back through the pics but I'm guessing coil overs moved in board a little . Needs to be seen back on the track !
                    Sandown 1.23.31
                    Calder 1.05.76
                    Phillip Island 1.47.95
                    Winton 1.33.30
                    Bathurst 2.47.49
                      Yeah, now that's cool!
                      What kind of steering column is that you have got in there?
                        Classic Auto Fabrications:
                          Love this car, still got the same auto?
                          ― Jim C. Hines
                          ― Daniel Patrick Moynihan
                          ― Napoleon Bonaparte
                            Do you run a residual line pressure valve on your front brake circuit? Is that to help reduce pad knock?
                            Cheers Alex.
                              Cheers Alex.
                              Yeah, 2 psi one, slows the car down a touch but makes the pad knock off disappear (stub stiffeners helped hugely too)
                              It doesn't lack top end speed anyway
                                Stock VL column with all the shit cut off it
