Cheetah Mk7
    Yea I recently revived my build the other day, have a deadline of Feb as will have a similar new responsibilty to look after.
    How's the XB going also?
      Since the XB went to alphabet track day in October last year it has backed out of the garage, driven to the end of the court and backed back into the garage. Given that October is coming up again it may be time to overhaul the master cylinder and machine the discs so that it will be ready for this years outing. If the XB goes anything like it has every other year, it won't be the fastest car there, but it will spend far more time on the track than any other car there.
        Yea cool and atleast it got started and driven even if it was only for 3minutes 45s.
          I was at Winton today and it was going very nicely, but just before the end of the day it broke the distributor gear and to top that off it had also blown a head gasket. So with no ignition it was impossible to fire up the engine to drive any water out of the bores. I think I know what caused the head gasket to go and if I'm right I will definitely need another set of heads. I just tried looking up the CHI website, but it appear to be down.
            Ah spewin about the motor, so what the distributor jumped a tooth and made it ping which pushed out the gasket?
            The CHI business was sold recently but that shouldn't stop the site I suppose, I grabbed the 2V's which was awesome as a straight bolt on, the thing that struck me the most was actually the turn in improvement with the reduced weight.
              I purchased the heads off a friend of mine about 6 years back. Unfortunately when he opened up the chambers he came a bit too close to the fire ring in a few places. He got away with it on his car for years and years, but I suspect that I have fallen foul of the issue.
              The turn in is another reason to consider the alloy heads. Resistance to detonation is also another big one, even though I'm certain that it isn't detonating. Being able to run without any valve seat lubricant would also be nice.
              The other thing is that a lot of the Falcons at these fun days have had $20k thrown at the motor, so you are all over them under brakes and around the bends and instead of them being polite and letting you through down the straights they want to drag race. So my poor little 351 with home ported heads and a quiet exhaust has to try and compete with a stroker in a straight line. It does pretty well and they don't pull away, but I don't get to shoot past them like I did a few years back either.
                Yea that makes more sense than my theory,
                The Alloys are an easy 50hp bolt on with more comp plus more low end torque...mmmm
                  Yeah, I do miss my old CHI headed motor... should have kept it as a street car for alot longer.
                    I was talking to Leon at A1 highperformance today and we were looking at some sweet Edelbrock Victor heads for Wheezors and I started talking about my heads and what could be done to them.
                    He basically said to get a solid roller cam instead...oh dear!!
                      Found out why the distributor gear broke. The oil-pump pickup broke off flush with the oilpump and some pieces of the pipe thread went inside the oil-pump and seized it. This in turn twisted the oil-pump drive shaft, broke the distributor gear and stopped the motor before any damage could be done. Looks like there has been zero damage to the engine. Very lucky.
                        Smart buggers at Ford must have been stoked when they thought to put that little fail safe design into the SBF.
                          I honestly can tell any difference driving on the street. Hopefully I will be able to notice a difference at Winton.
                          The change to XA/XB upper arms from the rubber bushed XC upper arms made a bigger difference. Roller spring perches did didly squat with the XC arms.
                            What have I misssed, did you get some alloy heads?
                            Will check your other thread or is this on FF?
                              This is the only thread. The engine got CHI 2V heads when it got reassembled.
                                Woohoo!!
