Project XH
    Project XH
    Well, I've finally "sat" the engine in the bay. Hopefully now it'll all start rolling from here. Any of you who've seen it in Street Fords magazine might remember how sexy it looked stock!
    Then the idea of going turbo.
    Then all new suspension and rims (minimal bling)
    Then we get serious
    And yes, the engine isn't straight. Gotta sort out the sump vs crossmember clearance issue next. Otherwise, stock XH engine mounts fitted perfectly.
    https://www.youtube.com/hoontv
    www.facebook.com/hoontv
    www.instagram.com/hoontv
    https://soundcloud.com/thehoonatics
    etc etc
    Im pretty sure it should all bolt in, apart from having to remove the front swaybar. oh and car looks good =]
      looks good so far.
      what are the motor specs? i'm very interested as i'm leaning towards doin a turbo xh falcon ute towards the end of the year
        Originally posted by gat5rodeo View Post
        looks good so far.
        Will have a full built engine, T51R, manual 3 speed auto etc
        Plan is for it to be "stoopid fast"
        etc etc
          Is it normal to run the plug leads straight into the turbo??
            Yes... but only when running the 0psi boost and flesh hands pipe manifold setup. ps: I lol'd at that one for seconds
            etc etc
              Ahh so your plan is exactly the same as mine,right down the the stoopid fast part:rotflol:
              EDIT:well apart from the fact I dont want no girly T51R...
                Girly T51R... as approved by Mister T!
                etc etc
                  haha copy cat!!!
                  nice work!
                  Did you run the 51r on the sohc motor? How did it go? Does it have the 1.05 rear housing?
                  Maverick - gone
                  Turbo AU Ute
                    What are you doing with the old motor/box?
                      PM sent
                      etc etc
                        RotaUte: you rock. i will have to go an get a copy of street fords now.
                        How was the bonnet clearance in the XH?
                        You're forgetting that the XH ute has the EF type front end crossmember under it. I'm pretty sure the sway bar is at the rear of the crossmember then. It wouldn't foul in the same way it does on our X cars. I take this to mean you aren't running one at all then? I did that for a while and then ended up spacing it down a bit to clear. A custom sway bar is pretty much the only way.
                        I have been scoring quite a few turbo parts for my NA twin cammer. Also just bought an XG ute. NFI if i will put it in that or just use it as a parts hack until the next dream machine comes along.
                        watching this thread with keen interest!
                          Taking this one in the Dutton Rally Boxer?
                          (TM - AVENGE)
                            Well, it does have coil overs and retrofitted BA leafs (they bolt in ) and hopefully soon big stoppers. Would be interesting to launch it off the transbrake at Goulburn airport.:rotflol:
                            etc etc
                              I hear Mossy is introducing a burnout comp, so you might win something
                              (TM - AVENGE)
