Whinge about shit HERE.
See more
See less
VL street/circuit
    VL street/circuit
    Since ive been on this forum for a while now its about time i posted up pics of the mighty non swedish VL . I bought it as a completely std VL exec 5ltr auto and over the last 7 years have been hitting all of the vic tracks and its now at the point where its not really a street car ( its still rego'd) and is driven only to the track and back . Its always been a budget track car but over the last year its had a few upgrades and times are now a bit quicker than when i started , sandown and winton are now 8 secs a lap quicker!! .
    Pic as i bought it for 3k
    First mods included a 5 speed supra conversion using a VC V8 pedal box and a little massaging of the firewall ( its now on its 4th supra 5sp) , 2nd hand pedders shocks/springs , HDT extractors ( to suit a manual ) , sway bar upgrade and a 3.45 ratio LSD and quick spin on the dyno pumped a healthy 93rwkw :). Also upgraded the brakes to twin spot corvette calipers and 330mm rotors .
    The car stayed like this for a couple of years as i just waited for the engine to die , little upgrades included better off set 16's ( always running on R888's) HDT cold air crap , strut brace etc.
    Next was the engine rebuild :)
    Full rebuild with the usual reliability add ons
    Ported VL heads , crane rollers , crane solid 272 cam , smoothed valley , performer manifold , holley 650dp , bigger extractors/zorst , acl's new oil pump etc. Made a solid 210 rwkw.
    That one lasted a year before oil starvation at PI due to incorrect sump :( , it was rebuilt and lasted 3 events before spinning a bearing . This is where TK and PF came to the rescue and advised on bearing clearences , drain backs , high volume oil pump etc . Ive learnt a heap about making a 304 live now even though its not a healthy engine atm it will get me untill mid year i hope when i do another full rebuild but this time its getting shipped to adelaide to knights race engines ( hi Tony :) ) where hes already adviced to throw away the VL heads , get a torker manifold( check) and let him do the rest .
    Pics in action
    output
    ive got more pics of fuel system , shocks and other stuff ill add later
    adam
    Sandown 1.23.31
    Calder 1.05.76
    Phillip Island 1.47.95
    Winton 1.33.30
    Bathurst 2.47.49
    Geee i bet thats fun to drive, by the pic i see you've discovered light arse lsd vl handling. Fun hey ;) Ive got a turbo vl and man it does that easy.
    Originally posted by Einstein
      Ive recently overhauled the entire fuel system from boot to engine having ditched the black carter pump and std fuel lines and installing a boot mounted surge tank to a barry grany pump with -8 lines to the carby and -10 returns to the tank .
      I was able to install the new fuel log and return reg as one between carby and manifold
      Also at the end of last year fitted bilsteins front and rear , using an idea HSVSUX emailed me firstly for the rear coilovers and then getting quadrant to make the fronts.
      In action at winton
      Sandown 1.23.31
      Calder 1.05.76
      Winton 1.33.30
      Bathurst 2.47.49
        Looks very tidy. Looks like a BT1(police) pack, unless the 1" master cylinder was standard on VL 5.0 retail cars.
          Well done Adam looks like a very neat car. It looks like you have some fun with the other Commodores at the wrx sprints.
          Now I just have to finish my own Vh race car.
            Thanks DJ , the cars mostly finished and just maintenece and little things to go . You building a proper "race" VH or just club stuff.
            adam
            Video of a good friend and myself at sandown last year .
            http://au.youtube.com/watch?v=2gfPIfDLru4
            Sandown 1.23.31
            Calder 1.05.76
            Winton 1.33.30
            Bathurst 2.47.49
              nice and clean, :thumbsup:
                Im building it to improved production specs but it will be a club car for a while until I get the skills and money up to race.
                  Few more mods in the works , have removed and sold most of the driveline and purchased some 2nd hand hotness .
                  Enter ex VX LS1 and six speed . Power steer / aircon removed . It was purchased without manifold / injection / loom .
                  Fitting one of these
                  Dale from CHE has supplied me with an ignition only loom which should arrive anyday now :) .
                  T56 is a big gearbox especially compared to the out going W57 supra box .
                  Supra weighed 48 kg's and T56 72 kg's but the flywheel used in the supra was the std holden 308 one and wieghed 15kg! . LS1 is far lighter so maybe only a 15kg difference at the end .
                  Next is sump / new clutch / starter conversion and extractors .
                  adam
                  Sandown 1.23.31
                  Calder 1.05.76
                  Winton 1.33.30
                  Bathurst 2.47.49
                    I weighed my Top Loader the other week - 71kg with iron bellhousing and crossmember... Suprised the T56 is about the same alloy case and all.
                      Nice new purchase mate. How long before its in and running?
                        excellent stuff! how are you going to go with the starter and the rack?
                          Hey jim , starter isnt a problem clearing a manual rack there is a little room to move . No space at all to run the extractors though :( , i thought you could sneak them between the steering shaft and chassis rail , but no way ( maybe one 2 inch pipe if that) so starter has to be moved for extractor clearence . Going to purchase the mal wood kit for $800 ish .
                          Datzed , still a few months untill skids . Sorting out engine mounts atm , cross member mounts look easy as its nearly lined up already . Then just have to hand over some folding stuff to finish .
                          adam
                          Sandown 1.23.31
                          Calder 1.05.76
                          Winton 1.33.30
                          Bathurst 2.47.49
                            Fucken top set of wheels dude.
                            Simple, thorough and effective.
                            Sean:)
                              I agree with Supercrown, nice, clean and looks like a heap of fun. It looks like it will be even better in the coming months too
                              are you going to run a 4 barrel style throttle body or change it all over to a carb?
