Morgan Park Track Extension
    photos of works in progress here:
    http://www.morganparkraceway.com.au/trackext.htm
    To make sense of photos, track will go straight on before turn 8, veering left in a corner with a similar radius to the bridge corner (ie fast), it will then go downhill for 100m or so,through a sweeping righthander (also fast) before slowing to an open righthander (ie a bit more open that the gumtree corner - bit still prob 3rd for most cars) and beginning to climb back up the hill. Then there is a right-left combination before cresting the hill and joining onto the front straight.
    Most corners should have some positive camber to them (except perhaps the last set coming onto the straight) so it should be a pretty quick section. As the front straight will probably effectively be a bit longer, and its likely to carry more speed onto it than now, turn 1 should be a bit more interesting with a harder stop req'd.
    Jason, 1983 GTV6 2.8, 1974 2000GTV Group Nc
    more progress pics are up
    Pulsar N14 SR20DE + Tomei - KG < $ = FUN
    Swift '08 daily.
      Looks good - now, even with a 4.375:1 diff, I'll be able to use 5th gear.
