Well interestingly one of the rear bushes had shown some sign of wear. This allowed the rear RH wheel to move back and forwards a couple mm. This was at full droop on the hoist. The feeling was that under load it would be ok, plus we didn't have time to replace it. So, not sure if this could have been 100% the reason. Perhaps it 'helped' contribute to the situation. The suspension is actually an old design of rear trailing arms much like the VW SuperBug type setup. If it was easy I'd consider changing to a more recent setup.
Had the X-rays. Ribs are cracked but neck ok, just pretty traumatised. Adrenalin worn off, now everything is starting to tickle just a bit!
I am convinced that it wasn't all my fault. The grip just went out from underneath me too quickly. Of course having wider rubber and stiffer springs is going to narrow the window of grip to slip but I've been through that corner as fast or faster before and felt more secure. Some people on another forum are saying that I over-corrected but I think it's easy to pick apart something on video without being there. The rapid loss of grip will bring out your instincts but I also have a strong recollection of being very conscious of not letting the car snap back hard left to the inside wall. This generally produces much worse results than mine. So once I knew I was 'gone' I just wanted to straighten the car away from that inside wall. Not sure if trying to throw it into a spin once off the track would have induced rotation and bring down the car speed dramatically...or induced a rollover? What do you reckon?
