Unlikely...these are 9/16"s as it is! Big buggers. The problem is 30 year old Alu blocks. Going to have to strip the motor again and Time Cert them all.
Yes, that was the design brief when ordering them. Be curious what tq values other motors need to hold their heads down per psi? Ours starts lifting not much over 22psi...which just won't cut the Mustard this year. Be lucky to have much over 400whp with this backup motor. Looking at the winning GTR from last year that has double that on his 'low boost' setting doesn't give me much cause for optimism. Ah well, all about the journey they tell me....
You wouldn't be able to strip the thread on the steal nut if you where through bolting.Originally posted by 333pg333 View PostFrom memory, I think you can run all the way through on 8 out of 10 holes. Not sure the in's and out's of that concept though?
Pulling threads is always going to be an issue when torquing the head studs and then the extra forces from the boost in an Ali block. Let a lone an old block.
Just looked up the 4g63 and it's Iron block so much harder to pull threads.
Not 100% sure of the spec on these. They'd be deffo higher than run of mill though. They torqued it down to 100ft/lbs this time. Wanted to go higher but not worth the risk.Originally posted by dougmo View Postgood news mate, what is the head torqued too on those studs? are they just run of the mill arp's? or L19 or better?
Essentially this isn't the right platform to try and get modern levels of hp out of. Wish it did have an Iron block...that would make life soooo much easier!Originally posted by agentcrm View PostYou wouldn't be able to strip the thread on the steal nut if you where through bolting.
Hang on ?
It was my understanding that the 944 engine was basically half a 928 engine, but the 928 has an open deck block, clearly your's doesn't, is that standard ? and while we are at it does the 944 usually run an alloy bore or are iron sleeves standard fitment.
Meanwhile I realised that you are running the single cam cylinder head, I would have thought by now you would have swapped to a 4 valve head, they are the same bolt pattern." Racing cars don't have doors. Toilets have doors" : Keke Rosberg
