Bored at work. Thought I'd do an update for 2016.
New motor is coming together. It's actually a years old project that got covered in dust while dealing with other motors but eventually or finally I decided to finish it. Finally also, a twin cam 16v motor too!! Should provide a significant improvement over the previous 8v motors.
Due to the lack of torque and increase of lag with the last 2.5 8v motor we decided to do a stroker crank on this latest one. The stock 3ltr crank is 88mm and we've moved out to 94mm. Quite a jump but not outrageous. Combined with a 104.75mm piston we have about 3.2ltr capacity. The combo of crank and cc increase should get us some of the much missed torque from the old 3.1 8v motor with the added advantage of more headroom in the upper rpms with the worked 16v head.
It was decided rather than sleeve the block we had it Nikasil coated to retain greater original block structure and also reduced friction with the almost mirror coating. Custom CP pistons and Carrillo rods have been designed and built accordingly. The open deck block has been strengthened via a custom deckplate and the larger bore headstuds also have additional certs to allow higher torque loads when clamping it down.
While the head has been modified I don't have the flow ratings to hand. The stock 968 head actually flows approx 340cfm which is pretty decent as is. I think this one will flow more like 400cfm. We're not going with monster cam profiles as we want to retain a bit more tq lower down in the rpm range. The stock Vario cam setup has been removed and new twin cam pulleys have been made to run a front drive system with an extra pulley to pinch the belt in more at the crank pulley. We're also discussing getting a custom Damper made up by ATI to suit and then remove the balance shafts.
Once we resumed finishing this motor it was my intention to switch to an EFR turbo. I went through a bit of back and forth emailing with the owner / engineer of Full Race turbos in the US. It was going to involve a whole new system of 4 - 2 headers and twin X overs plus a new turbo back exhaust system too. That whole exercise was going to cost circa $10k and take more time. So I listened to good advice given by Paul and we will just put the motor into the car we have now and see what we get. If we need to make changes we can do it along the year.
Going to switch to an electric water pump also. Damn there's a ton of choice through Davies-Craig.
http://daviescraig.com.au/electric-water-pumps
Block is finished. Just waiting on cams to be ground and the cam drive system to be checked. Hopeful to have it down here before end of Feb.
