Whinge about shit HERE.
See more
See less
Heavyweight challenge - supra time attack?
    Thanks, did you mean this?
    Tk "For the head I'd do much the same as I did for OKE's supra head - stock rebuild with a good valve job & a little tickle in the bowls & short turns to get some more flow without spending a motza.
    Add valve springs & cams (Kelford 264/272's & their springs to suit) & you'd have a good head."
      Brian crower 272s are ordered.
      Bottom end is together, triple plate clutch due shortly for balancing.
      What's the recommendation on ecu / looms from those who run track cars?
      Option 1: keep the microtech piggybacking the stock ecu
      Pros: cheap
      Cons: no-one seems to want to tune them and keep telling me they're shit
      Option 2: go straight to a new ecu, new loom etc and sell off the old set-up.
      Pros: more tuning options, confident the wiring will be all new for run-in
      Cons: no idea what the sex is, I want a digi dash now too so twice the research, more $$ now.
      Cheers
        just get a haltech/vipec sorta range ecu and be done with it. once you change cams and injectors the stock ecu will be nowhere near right for idle and cruise and will always hamper the rest of your mods, like maybe you will go e85 once you can steer the thing?
        i know haltech does a digital dash?
        "And I know that arseholes grow on trees but I'm here to trim the leaves" Peeping Tom, Mike Patton
          Breing the thing out to Lakeside you faggot, show us what you have :)
          ― Jim C. Hines
          ― Daniel Patrick Moynihan
          ― Napoleon Bonaparte
            ^showoff - this might almost keep your's in view in a straight line, once it's built, lakeside, too many corners?
            Ps - Cunt
            Head will be started next week. Engineer booked tomorrow 10am to look at cage, seats, single etc.
              I have a motec m800 (new no options) and an m8 (all options) for sale if you are interested
              Profi
                Hey profi, yeah did see and do want, just need to find the extra couple of grand, you'll hear from me if I can pull it off shortly!
                  And then?
                  So this engine shit all got a bit serious, eh?
                    Yep - big block
                    Should've gone v12!
                    Imagine looking at the passenger door, the cage makes an X. The top left arm needs to be bolt in, the rest is good to go. Should be easy to sort.
                    Single turbo no problem
                    Fuel system no problem
                    Seats no problem.
                    Am procrastinating about cleaning the engine bay and rust off the cage etc.
                      Purdy:
                        I spoke with the boys today. First go at the head showed it flowing 350hp at .45 lift after first go.
                        Hoping it to be back at the end of this week.
                        On other news cleaned up the crossmember a bit and it has a strange mark on it - it looks like " tiev " or "Tiet". Anyone know if this is factory? I'll get some pics up close.
                          Motor's back ready for final assembly.
                            I spent the day on the cage today. One more going over and then ready for etch primer. Before
                              About an hour in
                                Lots of fucking sanding later
