Charade V6 budget hillclimber
    Summit online are as convenient as anyone for rod ends.
    For a simple wishbone layout and geometry have a look at MX5's or C5 Corvette for ideas.
    Claimed horsepower sceptic.
      Been a bit busy with other stuff but have managed to sneek out after the kids were in bed a few nights and make a start.
      Have pulled the engine from the camry and started to strip the back of charade. Now the engine is out it looks fucking enormous. Bit worried about clearance on the right hand side of the engine where the pulleys are.... that might limit any options for suspension changes at the back. Maybe when the A/C compressor, power steering pump and steering rack disappear it won't look so bad.
      Anyway have started to take some measurements and will throw it all into autocad and see what the options are.
Name:	14_07_2012 005 rz.jpg
ID:	6574785Click image for larger version
Name:	14_07_2012 008 rz.jpg
ID:	6574786Click image for larger version
Name:	14_07_2012 011 rz.jpg
ID:	6574787Click image for larger version
Name:	14_07_2012 012 rz.jpg
        It'll look a lot smaller once all the superfluous shit is stripped off. They fit north/south in early Toyota's easy enough but still not a compact engine.
        GT8
        1UZ Celica
        1.07 flat Wakefield Park
          THe post that follows will be a thought provoking and deeply philosophical essay which will quite possibly alter your outlooks on life
          Originally posted by Mr Purple;
          What is with that smell every time you walk into an Aldi?
          I'm assuming it's something to do with all the cardboard boxes. Smells like eastern Europe, the fall of communism and peasants.
            No need for all that Autocad malarkey
            Tape measure and gas axe is all that's required
            Get to it
              I like and endorse this project. PLEASE FINISH IT.
              Originally posted by Stix Z
                I've been plugging away at this in the evenings and have finally got the engine tacked into place. Fits like a tongue in a bum...
                Also picked up some seats and harnesses for a couple of hundred.. pretty terrible but will do for a start I reckon
                Next I want to make a start on the cage but need to get my lathe set up so i can make up a 50mm die for my bender.
                  It's a shame you can't register something like this (assuming you do it properly of course)
                    Looking good.
                    Fortitudo et Superbiam
                      If you did the required torsional and rigidity testing you might be able to pull it off. there is nothing that says you can't change the drive from one end to the other.
                        Should leave the power steering rack in it for lols so it turns like a forklift.
                          how does the engine come out now?
                          Originally posted by Marv
                            Fabric rollback sunroof?
                              To get the engine out i unbolt the subframe and strut tops, lift the shell up and roll the lot out. This will be how most major work on the engine will have to happen i think. Going to try and make it as easy as possible to disconnect stuff to do this.
                                Awesome project, if youre planning on running in some of the local sprint events you might come up against a little green suzuki hatch with a bike engine (i think?) in teh back
                                sounds incredible and is pretty quick
                                1UZ+1NZ...
