Charade V6 budget hillclimber
    Awesomesauce.
      why not just make a full chassis car and drape panels over it?!?
      Originally posted by 50RTD
        Yeah this is what I should have done but I think I've gone too far to change now.
        Maybe the mark 2 can be a full chassis.
          hindsights a bitch hey!k
            looking great man!
            Originally posted by Mr Jones
            Farmer its all about how you cut them up, like a dead hooker jigsaw puzzle.
                yo kneelo,
                anything stopping a 85kg lighter g100 charade from being used for a similar mid engine conversion? were there any reasons why you didn't use one? just curious. cheers
                  I prefer the shape of the g200 and there was one available nearby cheap... Having said that the only original charade parts that will be left is the exterior panels and lights, some of the body and the steering system, so I'm not sure a G100 would end up weighing much different. Anyway there are already plenty of quick g100's around but not many g200's.
                    Made up a fuel tank. 1.6mm steel coated inside
                    Modified the original pickup to suit the deeper tank
                    Patched up the firewall
                    subframe porn
                    pedals modified to mount the clutch master cylinder and convert the brakes to dual masters with a balance bar (which you cant see)
                    Made some new linkages for the shifter to move the cables so they come in from the front and reverse them to suit the reversed camry shifter
                    now with less doors
                    solid rack to lock out camry steering
                    hacked the wiring harness to try and remove all the extra... bit of a failure as i cant figure out what half of it is. started and ran though so at least it goes
                      Awesome
                      Sent from my LG-P990 using Tapatalk 2
                        you cray cray
                        awesome
                        Toyota Starlet
                        QR Sprint - 65.9 secs
                        QR Clubman - 70.2 secs
                        Gatton Street - 42.5 secs
                        Flickr - Picasa
                          Wholly fuck. It's been a while since I've visited this thread and well, haven't YOU been busy! Looks awesome!
                            whats stopping the chassis bending like a banana??
                              The subframe?
                              caprice nugget.
                                Dogballs is right... at the moment theres not much stopping the whole subframe bending up. The plan is to tie the cage to the subframe at the little wing plate things near the top coilover mounts.
                                Getting main hoop bent up today so hopefully i can get cage done over easter.
