Whinge about shit HERE.
See more
See less
Evo 8 racecar
    Looked good out there mate, the car is a credit to you
    SA IPRA cars 15, 51, 77 and 25
    (Sharperto Racing)
    http://www.iprasa.mx.com.au/
      Thanks mate, was good to see you all out there on the weekend... now hurry up and get your thing back out there!
        Nice work mate
        Chris O
          Some incar from the other week, and a few photos
          Going to have a look at cams and some adjustable cam gears to try and get a bit more top end power from it.
            Final race for the weekend, finally starting to get the suspension setup a bit better.
              Hey Andy, great looking car...production race cars had problems with the eccentrics on the rear control arms coming loose and the rear camber and toe being affected. I made some laser cut spacer shims in half mm incaments to replace the eccentric bolts and it stoped the rear end moving out of alignment. If you want the files so you can get some laser cut your self , send me you email address.
                That would be great, cheers, PM sent.
                  So after the first couple of outings in the car it was clear that the standard sump wasn't up to the task of keeping the oil somewhere near the pickup during cornering. I tried to fix this by overfilling the oil a little and welding in a baffle around the pickup similar to the Burschur racing sumps, which helped to fix some of the oil surge, but still didn't really help with the lack of oil volume. Only way to fix that was going to be to increase the overall capacity. Got a mate of mine to knock me up a larger capacity winged sump with a much improved baffle around the oil pickup, hopefully this will fix it for good. I also fitted a Tomei oil thermostat delete so the oil cooler will now be working full time.
                  Seeing as the motor was out of the car, I decided to fit some Tomei vernier pulleys and some slightly larger cams, which will hopefully give it a little bit more top end power, as it was dropping off just a little bit too early with the standard stuff.
                  Finished mounting my new oil cooler, hopefully it will work a little more efficiently than the oem unit.
                  Went back to the dyno yesterday to see if the changes to the motor had made any sort of difference.
                  Was fairly happy with the results, although the wastegate actuator on the new turbo I'd fitted would only let us make 20psi, so I'll have to change that over and see if a bit more boost will net any more power.
                  Regardless of this problem the motor still made more grunt than it had before, with a much more usable rev range and far better oil temps with the larger oil cooler, so I'm looking forward to seeing how it will go next week at Mallala.
                  I also fitted up the knockback springs to the rear brake calipers, along with lock wiring the pins that hold the pads in, which will definitely stop them being pushed out of the caliper.
                    how many tokens was the sump?
                      Think Dan's doing them for about $750ish
                        Been a little while since the last update... Finally managed to make up a sump on this thing that doesn't get oil surge, which is good because now I can concentrate on making it handle rather than worrying about whether or not it's going to chuck a rod.
                        Went out for the final state round of the year a couple of weekends ago, managed to qualify 2nd behind the always quick Sprinter of Chris Brown, and stayed there for race 1, lowering my pb to a 1:14.8, so heading in the right direction times wise.
                        Got the jump off the line in race 2 but definitely felt like there was something weird about the car heading into turn 1. Quickly worked out the rear brakes had jammed on, due to me over adjusting the hydraulic handbrake pushrod and blocking off the return port on the cylinder... doh! At least an easy fix, but still annoying and the first DNF for the car.
                        Rain came literally as we were rolling around to start race 3, so that made coming back through the field a lot easier, so I managed to win that race, along with the last one as well in the dark. All in all a pretty good weekend!
                        Plans are to now get everything tidied up and sorted over Christmas as IP will be running at the Clipsal 500 next year so I'd like to make sure everything can be as sorted and reliable as possible. Can't wait to send it through the chicane!
                        Here's a video from the first lap of race 3.
                          Great work Andy!
                            Is that rubber lip factory? Thanks!
                            (TM - AVENGE)
                              looks awesome. great setup
                                It's just a cheap fibreglass one off ebay from memory, same design as the ralliart lip.
