AR51 w/GSXR1000 buggy
    This is my first race (6 laps). Not much traction and a few mistakes.
      And heres me doing a few laps before popping my right rear tire on a rock. Rock is at 7:20. After I hit the rock I wasn't sure for a while there if I had a flat or not. So I limped on till it became apparant I definately had a problem and was about to be passed so pulled over.
        And a phone vid.
          Pity the tyre went. Looks like a great day otherwise.
          Mmmmmmmmm beer.
          Originally posted by ALLMTR
            Headed out to Dowerin again on the weekend, hit a roo on the way up which sucked, but the buggy ran well with no problems. Tried out some different tyres on the rear, buggy felt a lot easier to get the tail out. That didn't help lap times though, I came 5th overall behind another buggy, 2 wrx's and my nemesis in a ford laser!
              Todays effort:cry:
                How did I miss this! Awesome man just awesome!
                  For all the places to miss step a wheel that was a good outcome. Anoying for sure but your safe. Buggy is a small fix vs a rollover.
                  Got any damage pics?
                  Mmmmmmmmm beer.
                    Love this... Time for some reinforced arms?
                    Sent from my G8141 using Tapatalk
                      Hopefully have some pics tonight. Busy now fixing it as I have a 2 day event next weekend.
                        That's awesome ! Looks like a heap of fun.
                          More serenity! I actually lowered it a bit since last time.
                            Ok so i thought I would put some photos up of how the new arm is made (well this is how I do it anyway)
                            The plans actually have drawings needed to build a jig to make the arms. It consists of a flat plate of steel with a series of bolts to mount blocks of various sizes to. I had this stashed away in the shed from when I originally built it. Lucky I didn't leave it in the rain or it would of rusted.
                            After cutting up the bent A arm I managed to salvage the inner tube that mounts to the chassis and the chunky steel bits at the other end where the shock and the heim joint bolt up.
                            So I cleaned them up and put them in the jig.
                            https://lh3.googleusercontent.com/9j...iqsAEmJg=w2400
                            Looking at the plans I suss out the angles that the tube has to be notched at. Using an online notch calculator web page I print out pdfs with the curve of the "notch" on it. Cut this out and wrap it round the pipe, then use a marker pen to transfer it, then cut with grinder.
                            http://www.metalgeek.com/static/cope.pcgi
                                So thats where I am at now.
                                The last photo is a top down view of the lower, front right hand arm (the one that bent)
                                I am thinking of running a tube from the center of the top tube to the bottom left (as you look at the picture) and maybe a gusset or 2.
