Datsun 1200 ute X R35 GTR
    Because I don't want to transplant the 500 computers to run it.
    3D scanning
    3D modelling
    Structural certification
    3 and 5 axis milling
      What about front gearbox with a 12" standoff between the box and the transfer to get the transfer further back? Or do the standoff at the bellhousing/input shaft (fairly common with hollingers already I believe)
        Yep totally an option also, I'll report back I'm going to check some sizes today
        3D scanning
        3D modelling
          I have a samsonas 6 speed coming for this now, I got the last one in Aus or was a 5 month wait. Full dog sequential good for 1000 HP or so they say.
          3D scanning
          3D modelling
            What's the rough damage on that if you don't mind me asking?
              18500 plus GST with the rear adapter, I think has front adapter for a RB auto housing I think but I'll fuck all of that off and run 1 piece billet housing.
              Went and looked at velo seats to buy to dummy and no stock. It seems from my dummy fitting in my 3d scan and quick measurements of sitting against a wall i will physically fit in the cabin, which is a plus. I am going to remove the rear wall and move the glass back a bit to give more room, I think it will be relativley "comfortable" with these mods.
              I need to pull the VR motor as I am now up to a point where once I have the samsonas I need to scan it all and properly try to place the motor etc in the car, the space seems very limited between the seats
              3D scanning
              3D modelling
                Throw that in the S15 while you do the rest of this build? :D
                Find your Freedom
                Home Loans | Car Loans | Investment Portfolios | Property Management
                www.FreedomFunding.com.au
                www.ProgressiveProperty.com.au
                Click for PF Loans
                If you're thinking of buying, or that you may be paying too much on your home loan PM me for a no obligation chat!
                  Meh.
                  www.prerunner.com.au
                  - Facebook
                  - Instagram
                    Omg jokes cun, fucken epic!
                    - Facebook
                    - Instagram
                      So I bought an ADR approved velo today to try fit. I mean it fits but there is no real way there would be room for a gearbox next to you. I did some more measuring and seems it will be ok, motor with small custom bellhousing with the samsonas on the back. Then a torque tube to the transfer case behind the driver's seat. Seems this will work and have some clearance.
                      I also have the whole front end of the R35 off. Tomorrow I'll lift it up and pull the motor out and take some more measurements but seems ok from this point.
                      If I can get the box to finish just in front of the driver's seat that is the main battle. The next problem is room for turbos and a intercooler in the front. Once I am past that point I know physically it will fit, then the rest is just time and manipulation. The big ticket items I can't move within reason so if they can't fit I'll be finding a different chassis.
                      A Datsun sunny would be pretty easy.
                      3D scanning
                      3D modelling
                        It's a bit late but you could look at tillett if you want a narrow fia seat.
                          Need to be ADR as well cos need to get it regoed.
                          3D scanning
                          3D modelling
                            Pics please
                            1970 RX2 coupe, 13b turbo.
                            1973 Cortina, 5.0 Windsor
                            1974 808 sedan, 12a Bridgeport
                            1976 Datsun 260c Coupe
                            I've got a 1968 XT Falcon.........!
                              Just about to drop the front subframe and engine from the R35. I'm surprised that the length of the motor is about 530mm, a SR20 is 500. But every other dimension is massive.
                              3D scanning
                              3D modelling
                                Motor out.
                                3D scanning
                                3D modelling
