Nice. Its fcking huge.
2001 Nissan S15 200SX Spec-R
Cool engine swap!!Breaking stuff once is ignorance, twice is stupidity, three times is racing
http://www.performanceforums.com/for...chev-LS1-turbo
http://www.performanceforums.com/for...tchback-torana
http://performanceforums.com/forums/...ghlight=ari300
http://performanceforums.com/forums/...Dog-Piston-rx4
Looks spot on, thanks Al! - all systems go to retrieval tomorrow.
Should be fine, the filter is fully framed so basically cant suck through.Originally posted by fat910 View PostBeatiful work. Might be a silly question but are those retaining clips strong enough to oppose induction suction?
From what i understand 20kgs difference, as to how that was measured (ie, accessories) im not sure - either way its fairly light (which is ultimately why i went VQ30 over 2JZ - good 100kgs lighter in that respect)Originally posted by clutch-monkey View Postis there a noticeable weight difference compared to sr20?
one way only, and no way id get a bonnet on it other way aroundOriginally posted by NXTIME View PostLove your work!
Another possibly silly question: could the inlet top have been flipped around 180°?
yep, its mounted directly under the intake pipeOriginally posted by denmaster View PostIs there a blow off? Room for a recirc?
Had a quick play around with the plenum this afternoon, smoothed welds and painted wrinkle black... came up looking almost OEM.
Also slipped the driveshaft in, fits absolutely perfectly (with around 10mm slip in the slip joint).
yeah going to continue the theme throughout the rest of the engine bay, no shiny shit - OEM finish, wrinkle black or satin black....
going to sort out a small plastic shroud for the air filter so that will disappear into the engine bay as well.
Al has done a great job fitting it all in, just need to make it all 'disappear' now.
