2001 Nissan S15 200SX Spec-R
    Been a bit slow of late (pregnant wife, been overseas and flat out at work).
    Decided to go for E85 so am converting to top feed injectors (with new rails). My ID1000's rocked up last Thursday (along with speedflow for turbo coolant/oil lines, fuel rail connections and power steering).
    Other than that, tailshaft is in & floor has been cut for shifter (which sits around 75mm further back than stock, but still comes up through the standard console).
    Hoping to find a decent wack of time in the coming weeks.
      Well ive had a few weeks off work so decided to dust off the S15.
      ID1000's installed (and all plenum surfaces milled flat)
      And a few other bits and pieces from the past week:
      - Injector plugs, TPS, power steering pressure switch now wired
      - Clutch line made and installed, pedal is barely heavier than standard (1200kg clamp)
      - Turbo oil feed made and installed (pulling oil feed from oil pressure switch)
      - Started painting up bits and pieces in stain black
      - Battery relocated to boot and engine bay positive terminal installed
      - New power steering line (little more clearance than first attempt)
      ... and a whole heap of other shit ive forgotten.
      Not really a lot to show for a good 3+ solid days of work - but shit takes time i guess.
      Planning on getting the car down to OKE020's this week to get the last fabrication sorted.
        Fuckin tops mate. Manifold and fuel rails ended up neat as.
          Nice work
          UZJ200 Landcruiser
            Jizzed in my pants!. Looking awesome man.
              Fuck yeah that looks awesome. What's the eta for skids
                +1 love this thing, get'er done
                  wow
                  that's looking fuckin awesome
                  top job
                    Beauty!
                    ― Jim C. Hines
                    ― Daniel Patrick Moynihan
                    ― Napoleon Bonaparte
                      So this ended up at OKE020's for the final round of fabrication.
                      Scott sorted out my lower radiator hose which now consists of 2 x stainless bends, 3 x 90" silicone bends and modified thermostat housing then sorted out my 4" intake pipe (with BOV return).
                      While the car was there I made use of Scott's equipment and made a whole series of brackets and some work under the car on the hoist.
                      ....And then brought the car home for final assembly.
                      Haven't attempted starting yet but did power the car up and hit the starter, she started cranking and fuel pump switched on.
                      So ECU is firing up
                      Still a little more wiring, cover for air filter, 2nd walbro pump and fuel reg to install - but getting close to jet black lines :D
                        You're going to properly shit your pants when you drive this the first time. Serial.
                          that came up awesome.
                            Jesus. The most awesomely executed engine in a 200sx I can care to remember. Fantastic.
                              That is going to be soooo good.
                                not even going to bother with my s15 anymore
                                121 timez
                                1998 BT1 Sedan. RB30 plus baby seat
                                Originally posted by Mr Ed
                                Anything with Fukushima in the title is bound to be great click bait.
