High quality work, as usual
2001 Nissan S15 200SX Spec-R
Page mine! Is this the wrap you used on the hot pipes Jon? - http://www.summitracing.com/parts/dei-010127Hide yo' wife!!!
Yep thats the stuff.Originally posted by psssi98 View PostPage mine! Is this the wrap you used on the hot pipes Jon? - http://www.summitracing.com/parts/dei-010127
ECU powered up & upgraded to lastest Haltech firmware.
Wired and tested:
- Air temp sensor
- Coolant temp sensor
- TPS
- Ethanol sensor (tested with some old EFLEX, 68% - magic little box)
- Crank trigger
- Fan switching
- Clutch switch
- Fuel pump relays
Wired but untested:
- Boost control
- Shift light
- IAC (idle stepper motor)
- Ignition coils (12v power source OK)
- Injectors (12v power source OK)
- External MAP sensor
- Digital tacho synchroniser (6 cyl ECU outout – conversion box - 4 cyl dash tacho)
- High/low boost switch
Still to be wired:
- WB O2 sensor
Dimi, we are using the stock reluctor sensor with a different chopper disk.
On the front pulley they run a 175mm 3+1 tooth disk on the backside of the pulley, the disk that is now being used is 175mm 36-1 on the front side. The stock reluctor has just been spaced forward to meet with the new chopper disk.
So fking time consuming, but chipping away at it.Originally posted by psi999 View PostECU powered up & upgraded to lastest Haltech firmware.
Wired and tested:
- Air temp sensor
- TPS
- Crank trigger
- Fan switching
- Clutch switch
- Fuel pump relays
Wired but untested:
- Boost control
- Shift light
Still to be wired:
- WB O2 sensor
- WB02 sensor now wired and tested (cabin display and ECU input)
- shift light (CREE LED, bright as fark) wired and tested
The rest will probably have to be tested on startup, which i reckon wont be too long now :D
Well another productive weekend working on the shitbox.
- Clutch switch installed & triggering ECU correctly
- Ethanol composition sensor mounted, plumbed up and leak tested (Saturday morning run to buy all the required fittings)
- Crank trigger wiring heat insulated and run
- 4-port boost controller mounted (and wiring extended yet again for final location)
- Air temp sensor mounted in intercooler piping (thanks to OKE020 for fitting me in on Saturday morning)
Not a lot there but literally 2 days solid work running around collecting parts and installing – all my shit under the car jobs done now.
Just need to torque up the front pulley, reinstall wastegate and it’ll be startup time.
Also have been thinking about the two-step launch control and what sort of damage can potentially be done to the engine by engaging this mode?
This GTR is running Haltech launch control so basically the same setup.
Haltech vid on setup
Should I be concerned?
