In tonight's episode of OCD With Heat Shields, I decided to re-do the aluminium shield I'd made up before. I thought it looked a little goofy since it was twice as big as the actual cat itself, and in terms of function, was pushed too close to the rocker cover shroud for my liking, due to the brackets on the cat.
So I figured that it was as good a time as any to experiment with this stuff. I first noticed it being used by Ford in the XR6T, and was surprised to find that you can get sheets of the stuff from ACL
It looks like a two layers of thin ally, and initially I thought that maybe there was a sandwich of fibreglass insulation or something inside, but it seems that it's hollow, and relies on an air gap in the middle of the sandwich to do the insulating.
So...passing the point known as the One Of No Return, I start to dremel off the offending brackets off the cat.
Then make a cardboard template of what I want to make...
...not forgetting the brackets...the heatshield material isn't cheap at $70 for a 70x30cm sheet, so I figured I didn't want to have too many goes at making this
The brackets are cut from very thin 0.5mm aluminium, which is quite weak and floppy but the brackets will have a few folds in them for strength.
Now, to cut out the heatshield material, which cuts very easily with tin snips, and the waffle/grid pattern makes it very easy to cut it straight, too
Fold up on the vice...
Rivet on the brackets
And it's done!
It's much more compact than the stock cat and shield. In terms of weight, the old cat was 6kg, and the new one is 3kg.
The original version probably worked just fine, but this version is nicer
And there's now quite a big air gap between the cat shield and the rocker cover shroud
All done!
And it's done!
All done!
