Bought some gear for the build.
First was master cylinders. Even with manual master cylinders the front reservoir for the brakes, and the clutch reservoir fouled with the intake.
So I bought some willwood remote reservoirs (had to buy it with master cylinders though, so now I have the willwood master cylinders and willwood reservoirs to offload) and built a mount for the reservoirs in pretty much the only place they would fit. I still have to shorten the hoses of course.
Master cylinders with remote connections
GAS1600_044_01 by Garvice, on Flickr
Mount for reservoirs
GAS1600_044_02 by Garvice, on Flickr
GAS1600_044_03 by Garvice, on Flickr
I also bought the maddat steering linkage. It is about 5mm away from the bellhousing at full lock (hard to see in photo), so i'll just remove some of the rib from the bellhousing.
GAS1600_044_04 by Garvice, on Flickr
GAS1600_044_05 by Garvice, on Flickr
GAS1600_044_01 by Garvice, on FlickrMount for reservoirs
GAS1600_044_03 by Garvice, on FlickrI also bought the maddat steering linkage. It is about 5mm away from the bellhousing at full lock (hard to see in photo), so i'll just remove some of the rib from the bellhousing.
