Gas 1600
    That's awesome Brad. Sounds killer. Love that boot lid too!
      I do want to paint it, but have thought about leaving it how it is as well. Will have to think it over. Real issue is things like windscreen seals and all the door rubbers etc. need replacing. So if I replace them before paint ill just have to do it again after paint.
      GAS 260Z RB26DET
      GAS 1600 3SGE BEAMS
        come and grab my epotec epoxy primer kit i have here. $0. even have the thinners
        ferny hills
          Somehow missed your message Tim. Thanks for the offer, if you're sure you don't want it I'll take you up on that. Will send you a pm later in the week to organise a time.
          Brad
          GAS 260Z RB26DET
          GAS 1600 3SGE BEAMS
            No worries mate, I'm never gonna use it.
              That video. Fucking. Yes.
                Alright, I sat down and wrote a list of jobs to do. Probably isn't everything, but will give me something to work with.
                • Wiring
                  • Headlight Wiring
                    Turn Signals
                    Brackets for Engine bay wiring
                    Fuel Pump/Sensor
                    Rear Lights/Demister
                    Wipers
                    Mount indicator stalks
                    Radiator Temp Switch
                  Rust Repairs/Metal Work/Fabrication
                  • Roof line above rear drivers door
                    Boot water channel
                    Drivers Door
                    Drivers Qtr Panel/Bottom Mount
                    Drivers Qtr Panel Mounting Flange
                    Passenger Door
                    Passenger Qtr Panel/Bottom Mount
                    Passenger Qtr Panel Mounting Flange
                    Front Grill Brackets
                    Exhaust cutout
                    Hand brake mount
                    Hand brake pinion lever reversed/remade
                    Dashboard strip down/fabrication
                    Steering Column Mount
                    Exhaust outlet
                    Brake line mounts, tunnel/radiator support
                    Heater Install
                    Air intake/filter
                    Radiator Fan Install
                  Purchase
                  • Handbrake cable
                    Heat shielding
                    Windscreen seal
                    Rear Window seal
                    Door Seals
                    Window Seals
                    Boot Seal
                    Bonnet Seal
                    Seat belts
                  Mount
                  • Front Bumper
                    Front Grill
                    Front Light Buckets
                    Front swaybar
                GAS 260Z RB26DET
                GAS 1600 3SGE BEAMS
                  Got a couple of hours in the shed this weekend.
                  Mounted the Altezza indicator/lights and wiper stalks on the 180b steering column. Couple of small welds on the bracket from the altezza. I'm not convinced about the plastic surround, much bigger than it needs to be, but will be nice to have good quality new switches.
                  GAS1600_057_01 by Garvice, on Flickr
                  GAS1600_057_02 by Garvice, on Flickr
                  Mounted the Maddat swaybar. Was a pain in the rear (nothing is easy with this engine/car combination). Ended up mounting it upside down to clear the sump. Fouled on the sump and the oil filter the other way.
                  GAS1600_057_03 by Garvice, on Flickr
                  GAS1600_057_04 by Garvice, on Flickr
                  My new exhaust was fouling on the handbrake cables, so i had to lower the saddle a little. Ended up just making a simple modification to the pinion lever so that the saddle sat about 10mm lower. Was enough to give me the clearance needed to the exhaust.
                  GAS1600_057_05 by Garvice, on Flickr
                  GAS1600_057_06 by Garvice, on Flickr
                  GAS1600_057_07 by Garvice, on Flickr
                  I also welded on the nuts for the front bumper, so it is finally properly mounted. No photos.
                  GAS 260Z RB26DET
                  GAS 1600 3SGE BEAMS
                    Having issues with the willwood remote masters leaking at the reservoir end. Thinking of measuring up to see if the Tilton job will fit. It's much bigger than i need though and not sure it'll work well there. Only other option i can think of is getting the remote feeder section (where the reservoir connects to) made out of aluminum. All other remote options seem to be too small (1oz motor bike type jobs).
                    Anyone else no of other good options? (Needs a way to be mounted too, ideally that doesn't look like a stainless zip tie/bandit strap).
                    GAS 260Z RB26DET
                    GAS 1600 3SGE BEAMS
                      This first job wasn't on the list, but had to be done.
                      These willwood reservoirs kept leaking (alternating, but mainly the largest one). Might of been something to do with different brand reservoirs or might of been the plastic on plastic connection. Either way I gave up on these which meant I needed to make a new mount.
                      Out with the old.
                      GAS1600_058_01 by Garvice, on Flickr
                      In with the new.
                      GAS1600_058_02 by Garvice, on Flickr
                      GAS1600_058_03 by Garvice, on Flickr
                      GAS1600_058_04 by Garvice, on Flickr
                      This shows the new reservoirs are still higher than the cylinders
                      GAS1600_058_05 by Garvice, on Flickr
                      Started on a job on the list, mounting the handbrake. I need to weld the brackets in permanently, make a new cover to seal the tunnel and have a cable made. It is an R33 handbrake.
                      GAS1600_058_06 by Garvice, on Flickr
                      GAS1600_058_07 by Garvice, on Flickr
                      GAS1600_058_08 by Garvice, on Flickr
                      GAS 260Z RB26DET
                      GAS 1600 3SGE BEAMS
                        super work!
                        Jason Broadhurst
                          What's (who's) that reservoir from?
                          Marc Kelly
                          '76 1380 Clubman (I really should fix it)
                          '86 AE82 Twin Cam (cunts trashed it, gone to the wrecker)
                          '85 JD Camira rally car (I trashed it, now its a Lanos)
                            Cheers. Reservoir is a tilton and i got it (next day service) from racerindustries.com.au
                            GAS 260Z RB26DET
                            GAS 1600 3SGE BEAMS
                              Nice man!
                                Originally posted by garvice View Post
                                In with the new.
                                Do they have a bellows of some sort under the cap?
