Gas 1600
    They have a filter but not a bellows as standard.
    GAS 260Z RB26DET
    GAS 1600 3SGE BEAMS
      Sealed up the handbrake mount. Need to get a cable made.
      GAS1600_059_01 by Garvice, on Flickr
      GAS1600_059_02 by Garvice, on Flickr
      GAS1600_059_03 by Garvice, on Flickr
      Also got my headlight buckets and bulbs mounted up. Went to wire them up only to find my crimpers can't get around the H4 connector angle plugs. Job for another day now.
      GAS1600_059_04 by Garvice, on Flickr
      GAS 260Z RB26DET
      GAS 1600 3SGE BEAMS
        It's looking good!
          Hope you're planning on replacing the fluid fairly regularly then...
            I haven't tested the hole in the top top see if it's straight through but even if it is it's pretty small so can't see much moisture getting in. Not to mention the reservoirs are massive. With manual brakes I think I'll be able to register if the fluid is gaining water.
            GAS 260Z RB26DET
            GAS 1600 3SGE BEAMS
              The only way you tell is when the fluid boils and the pedal goes soft... or the trapped moisture corrodes stuff. either way - just bleed it regularly and you'll be right
                - Plumbed in the new brake reservoir
                - Installed the Toyota Altezza windscreen wiper motor and extended the altezza loom. I searched for 5minutes for a proper pinout/wiring diagram of the factory 1600 motor before saying, stuff it the altezza motor is newer, so spent the next hour and a half making it fit. It has the motor sticking out the opposite direction to the 1600 motor and required a slight modification of the bracket to make it fit nicely with where i had installed the fuse box. Also ended up welding the arm onto the motor shaft as i stripped the bolt trying to press fit the arm on. After all that, it actually works rather nicely. I did have to also press out one of the wiper mechanisms (drivers side) shaft as it was seized. Probably should give the mechanism a coat of paint, but couldn't be bothered at the time.
                - Fixed the temporary mounts in the tunnel for the brake lines.
                Current Job list with completed jobs underlined.
                Wiring
                • Headlight Wiring
                  Turn Signals
                  Brackets for Engine bay wiring
                  Fuel Pump/Sensor
                  Rear Lights/Demister
                  Wipers
                  Mount indicator stalks
                  Radiator Temp Switch
                Rust Repairs/Metal Work/Fabrication
                • Roof line above rear drivers door
                  Boot water channel
                  Drivers Door
                  Drivers Qtr Panel/Bottom Mount
                  Drivers Qtr Panel Mounting Flange
                  Passenger Door
                  Passenger Qtr Panel/Bottom Mount
                  Passenger Qtr Panel Mounting Flange
                  Front Grill Brackets
                  Exhaust cutout
                  Hand brake mount
                  Hand brake pinion lever reversed/remade
                  Dashboard strip down/fabrication
                  Steering Column Mount
                  Exhaust outlet
                  Brake line mounts, tunnel/radiator support
                  Heater Install
                  Air intake/filter
                  Radiator Fan Install
                Purchase
                • Handbrake cable
                  Heat shielding
                  Windscreen seal
                  Rear Window seal
                  Door Seals
                  Window Seals
                  Boot Seal
                  Bonnet Seal
                  Seat belts
                Mount
                • Front Bumper
                  Front Grill
                  Front Light Buckets
                  Front swaybar
                GAS 260Z RB26DET
                GAS 1600 3SGE BEAMS
                  and then? the punters are keen for an update.
                    I'm keen for an update too. This year was my do or die year, had to get it on the road. Unfortunately the last 6 months has been crap with work. Also built this work a mate for his 10 month old. He wanted a plywood and wheel barrow wheel kart. I told him we could do better.
                    GAS 260Z RB26DET
                    GAS 1600 3SGE BEAMS
                      Also lost the key for the half cut which is a very bad thing. If i don't find it ink afraid I'll install my motec on it and then it will turn into an even longer project.
                      GAS 260Z RB26DET
                      GAS 1600 3SGE BEAMS
                        Well another years gone with no work on either of the datsuns. Almost finished this for the boys though.
                        GAS 260Z RB26DET
                        GAS 1600 3SGE BEAMS
                          That's pretty trick, wheelchair DC motors i take it? I like that the engines are hooked up before the steering has been finished.
                          Love the kid Kirkeys too
                            Just ebay dc motors. Only 500W a piece. Needs some 250cc engine or something.
                            Yep seats came up alright, thought about adding lightening holes but they're already pretty light.
                            Steering, they'll steer with there right foot. Seriously though, it has been done, pending a leather wrap on the wheel (still waiting on ebay), but have left out until I get the accelerator pedal back in.
                            GAS 260Z RB26DET
                            GAS 1600 3SGE BEAMS
                              Almost 2 years (20.5months) since I last worked on the datsun. Got out to the shed today and did a little work, no pictures yet.
                              Fixed the drivers qtr panel mounting flange (welded new nuts on/fixed rust) and fixed the passengers qtr panel rust. Also noticed the passenger side qtr had a lot of bog do needed sine reshaping.
                              Wiring
                              • Headlight Wiring
                                Turn Signals
                                Fuel Pump/Sensor
                                Wipers
                                Boot water channel
                                Drivers Door
                                Passenger Door
                                Exhaust cutout
                                Hand brake mount
                                Exhaust outlet
                                Heater Install
                                Air intake/filter
                              Purchase
                              • Handbrake cable
                                Heat shielding
                                Windscreen seal
                                Rear Window seal
                                Door Seals
                                Window Seals
                                Boot Seal
                                Bonnet Seal
                                Seat belts
                              Mount
                              • Front Bumper
                                Front Grill
                                Front Light Buckets
                                Front swaybar
                              GAS 260Z RB26DET
                              GAS 1600 3SGE BEAMS
                                This is amazing. Your quite a way through it now, may as well get stuck in and finish it. Will be an unbelievable car.
