Gas 1600
    Thanks mate, yeah had a bit of a speed bump in progress last 2 years, really just need to get it on the road.
    GAS 260Z RB26DET
    GAS 1600 3SGE BEAMS
      Well I managed to get a couple of days in the shed. Last month a couple of mates helped me out on the datsun and we ended up with a fan mount for the radiator. Still need to weld in a boss for the water temp. switch but it's another job off the list.
      I also got out to the shed today and finished off the front quarter panels. Both needed new top and sill mounts. The passenger side needed to be rebuilt at the sill section and was in pretty rough shape at the front from a previous prang and dodgy fix. Required a fair bit of work to get it to meet up with the radiator support and front valence. Now i have both front quarter panels fully mounted for the first time. The panel gaps are not the best but I just have to keep reminding myself it's a 47 year old car and if I keep working this slow on it the car is going to be 50 before it's on the road.
      Only got a few quick photos for you guys of the lower sill repair on the guard, didn't take any photos of the mounts or other repairs along the way sorry.
      GAS1600_055_ 01 by garvice, on Flickr
      GAS1600_055_ 02 by garvice, on Flickr
      GAS1600_055_ 03 by garvice, on Flickr
      GAS1600_055_ 04 by garvice, on Flickr
      GAS1600_055_ 05 by garvice, on Flickr
      GAS1600_055_ 06 by garvice, on Flickr
      GAS1600_055_ 07 by garvice, on Flickr
      GAS1600_055_ 08 by garvice, on Flickr
      GAS1600_055_ 09 by garvice, on Flickr
      GAS1600_055_ 10 by garvice, on Flickr
      GAS1600_055_ 11 by garvice, on Flickr
      To keep me honest/motivated, here is the job list with more jobs struck off.
      Wiring
      • Headlight Wiring
        Turn Signals
        Brackets for Engine bay wiring
        Fuel Pump/Sensor
        Rear Lights/Demister
        Wipers
        Mount indicator stalks
        Radiator Temp Switch
      Rust Repairs/Metal Work/Fabrication
      • Roof line above rear drivers door
        Boot water channel
        Drivers Door
        Drivers Qtr Panel/Bottom Mount
        Drivers Qtr Panel Mounting Flange
        Passenger Door
        Passenger Qtr Panel/Bottom Mount
        Passenger Qtr Panel Mounting Flange
        Front Grill Brackets
        Exhaust cutout
        Hand brake mount
        Hand brake pinion lever reversed/remade
        Dashboard strip down/fabrication
        Steering Column Mount
        Exhaust outlet
        Brake line mounts, tunnel/radiator support
        Heater Install
        Air intake/filter
        Radiator Fan Install
      Purchase
      • Handbrake cable
        Heat shielding
        Windscreen seal
        Rear Window seal
        Door Seals
        Window Seals
        Boot Seal
        Bonnet Seal
        Seat belts
      Mount
      • Front Bumper
        Front Grill
        Front Light Buckets
        Front swaybar
      GAS 260Z RB26DET
      GAS 1600 3SGE BEAMS
        Love this car. Keep going!
        CJM 4 Life yo!
          Cheers mate
          GAS 260Z RB26DET
          GAS 1600 3SGE BEAMS
            got a oem temp/fuel gauge handy? i need some specs from a few to test a theory. 2 mins with a multimeter
              Yeah I think I do Tim. Send me a pm of what you need.
              GAS 260Z RB26DET
              GAS 1600 3SGE BEAMS
                Got photos working again, dreading having to redo all those dead links for the photobucket posts though.
                GAS 260Z RB26DET
                GAS 1600 3SGE BEAMS
                  Got to work on the 1600 again.
                  Fixed my bent valence mount. Made a drivers side grille mount and mounted the grill/light surrounds. Not a perfect fit but again, it's an old car and it just needs to get on the road, so I'm not tweaking the mounts any further.
                  Fabricated drivers side grille mount on left, original Datsun passenger side grille mount on right.
                  GAS1600_056_ 01 by Garvice, on Flickr
                  GAS1600_056_ 02 by Garvice, on Flickr
                  GAS1600_056_ 03 by Garvice, on Flickr
                  GAS1600_056_ 04 by Garvice, on Flickr
                  To keep me honest/motivated, here is the job list. Decided to cull the jobs that are now done from the list rather than underline.
                  Wiring
                  • Headlight Wiring
                    Turn Signals
                    Fuel Pump/Sensor
                    Boot water channel
                    Drivers Door
                    Passenger Door
                    Exhaust cutout
                    Exhaust outlet
                    Brake line mounts radiator support
                    Heater Install
                    Air intake/filter
                  Purchase
                  • Heat shielding
                    Windscreen seal
                    Rear Window seal
                    Door Seals
                    Window Seals
                    Boot Seal
                    Bonnet Seal
                    Seat belts
                  GAS 260Z RB26DET
                  GAS 1600 3SGE BEAMS
                    Spent a couple of hours tonight fixing all the photo bucket dead images. Gave me a chance to reminisce along the way. Original goal of this car was to build a cheap car quickly, however the car required far more work than I thought and I definitely chose the hard way with most decisions. Some of the things I underestimated:
                    - Wasn't expecting so little steel and so much bog/rust
                    - Didn't expect to replace both floors/tunnel to do an engine swap
                    - Didn't think I'd need to build a new radiator support to offset the radiator
                    - Hadn't expected crash damage
                    - Completely forgot how anal I could be
                    Well my eldest who was 2 when I got this car turns 7 tomorrow so thought it fitting to remind myself of a few old naive posts.
                    22-09-12
                    Plans for this car are a quick (like to get it on the road late next year) and cheap build to give me something to enjoy while the Z sits in modification jail.
                    26-09-12
                    I'm not so sure about the "optimistic" quick and easy build statement.
                    Always fun nonetheless!
                    BP
                    This man had a Crystal ball!
                    03-02-13
                    Cheers mate, hope to have body work done by March/April.
                    Still doing body work. Ha
                    17-04-14
                    the original plan was a quick and cheap build that was going to be 12-18 months. Which if you go by my first post would put me at around October last year to March this year.
                    06-04-14
                    First engine start
                    Congrats bud. Downhill from here
                    16-05-15
                    Drove out of shed under own power.
                    Pretty much a black hole end of 2015 through early 2017 due to various other projects.
                    One thing I'd do differently, build in a bigger shed with another hoist as a car on your hoist for 5+ years is not cool. Ha.
                    GAS 260Z RB26DET
                    GAS 1600 3SGE BEAMS
                      Keep up the good work Brad. I doubt I'll get around to mine until 2019. Funny that you've been working on it for as long as 1600s were in production!
                        ^ Damn. I'm going to have to stop counting the 2 year hiatus and just say it's been 3 years of work.
                        GAS 260Z RB26DET
                        GAS 1600 3SGE BEAMS
                          Another 3 items off the list and I think i am finished with all the rust repairs on the main body, only rust on doors to go.
                          Had a boot channel to fix, wasn't real happy with how this turned out as I couldn't get the mig in far enough to get a nice weld and then since the weld was a bit large couldn't grind it out nicely due to the lack of space to get a grinder in. But, it will do, must avoid rework.
                          GAS1600_065_01 by Garvice, on Flickr
                          GAS1600_065_02 by Garvice, on Flickr
                          GAS1600_065_03 by Garvice, on Flickr
                          GAS1600_065_04 by Garvice, on Flickr
                          GAS1600_065_05 by Garvice, on Flickr
                          Minor holes behind the rear light.
                          GAS1600_065_06 by Garvice, on Flickr
                          GAS1600_065_07 by Garvice, on Flickr
                          Rust hole above rear driver's side door
                          GAS1600_065_08 by Garvice, on Flickr
                          GAS1600_065_09 by Garvice, on Flickr
                          Rear valence around exhaust. Need to get a smaller sander so i can file the weld. Also need to cut and weld a turndown on the exhaust outlet.
                          GAS1600_065_10 by Garvice, on Flickr
                          And I fixed a dint in the rear quarter. Just realised while doing this post that you can't really see the fix in the photos. But it used to be a dint, now it's smooth.
                          GAS1600_065_11 by Garvice, on Flickr
                          GAS1600_065_12 by Garvice, on Flickr
                          Wiring
                          • Headlight Wiring
                            Turn Signals
                            Fuel Pump/Sensor
                          • Drivers Door
                            Passenger Door
                            Exhaust outlet
                            Heater Install
                            Air intake/filter
                          Purchase
                          • Heat shielding
                            Windscreen seal
                            Rear Window seal
                            Door Seals
                            Window Seals
                            Boot Seal
                            Bonnet Seal
                            Seat belts
                          GAS 260Z RB26DET
                          GAS 1600 3SGE BEAMS
                            Awesome progress
                            If you need heat shielding and insulation check out Car Builders stuff (carbuilders.com.au) as it is cheaper than Dynamat anf Aussie-made
                              Thanks mate, I'll check then out. Will be looking for external barrier shielding type stuff for the exhaust on the firewall and transmission tunnel rather than the internal bitumen type stuff.
                              GAS 260Z RB26DET
                              GAS 1600 3SGE BEAMS
                                They have that stuff. Also have spray on ceramic liner too.
