Holden Ute
    Mid 11s with that launch is awesome.
      Ute for sale.
      PM for details and list of everything in it. Very well sorted.
      Does not fit my goals and I am no longer car person.
      $20k takes it. I'll deliver it free to anywhere on east coast of Australia happily
        Lol, again?!
        Originally posted by 50RTD
          Originally posted by cracka View Post
          Ute for sale.
          Is it Monday already?
          The World's Best Pest Control in Brisbane, at PF mates rates, PM me.
          when all else fails, hit it harder.
            Swaps for Stagea?
              Ute for sale.
              Wot. We need to do whis
                Now for sale ASAP.
                Need cash. PM offers or for full list of things done (everything possible but paint). No trades.
                Will deliver anywhere on east coast of australia.
                  $5k TT lowball offer
                    Trading up for turbo Porsche?
                      I'll buy it off you for $5k on the condition that you buy it back off me for $5k when you snap out of your current spot on the cracka mood scale.
                        $5001 ..
                        With TTs conditions
                          nvm
                            Well done. You made it to the other side. Stay for longer this time bro.
                              A few updates:
                              Thrashed the fuck out of this for past 3 days. Fairly hard run up mount glorious has given the diff terminal illness. Suspect it's the rear pinion bearing allowing the pinion to climb a little as it only groans happens under load, correlated to speed and freewheels fine. Uni's look brand spankers. Might also be gearbox output shaft/yoke bearing but I doubt it somehow.
                              Overheated the gearbox a little ok said run, saw 110 on the gauge (pan temp). Not ideal, but it'll never ever work that hard again (6-8mins of hard load and high revs).
                              That said this thing has felt slow... Tried to rip a 2nd gear skid at 80 down the gateway with no success and just lots of noise. So I took it to the stables and added more horses. The lack of power from a few weeks back with leaky exhaust up pipe pre turbo liberated a good chunk of power in the low end, but it never felt strong up high for past few weeks.
                              To summarise. Changed plugs to iridium as I figured it can't hurt a few days ago. Ones in there were 0.8-0.86mm, same heat range as new ones. Set the new ones to 0.78 gap figuring that'll be mint. Looks like that wasn't enough as it was blowing the spark out on the dyno. Quick change to 0.5mm and free horses were added. 60 of them. Glad it's a ute and has space for many horses.
                              But then power was laying over in the top end compared to first tune. Fucking Houdini horses in this cunt of an engine... Used to hold 415hp to redline with 430 peak across about 3000rpm. So I wound the boost down to 12... Power didn't fall off. Exhaust valve springs are on the out obviously and blowing open in the top end. Doh.
                              They must be losing a little tension from being flogged for 2500 turbod km.
                              Big thanks to scotty(oke20) for the dyno time and letting me use his tools.
                              Downside of tonight was the green floor after dyno runs. There's a water gallery cover plate on the RHS beside the engine mount that's weeping fluid. FML. Have to remove engine mounts and jack the block up to access it. Cunt. Adding tap water is easier for a few months.
                              Plans for this have taken a significant change. Unless it lifts a head or blows a gasket I'm not touching it until I own a house and a shed. Once those exist in my life I'll pull the block, give it all a bit of TLC. If the diff gets any worse I'll have to fix that but would rather not.
                              Hope to get it down the track next month when I'm back from work and see if it's got 120mph in it.
                                Green coolant in a toyota wnb.
                                If in doubt power out
