Vs Barra ute
    What brand exhaust,Redback or Scorpion?
    Looks like same exhaust on mine had to belt the shit out of just to fit then some more to stop it tapping floorpan.
      Moving the rack over?
        The mad professor at work
        I agree with Rdyno
          You must be working full time on this. I have a pair of front rotors you can have. They are the large 330mm ones from the UPC kit. They are like new still.
            Redback
            Not sure yet, will put rack in tonight and see, but seems lot tighter to rail compared to vb-vk
            Got a full time job on Tue, but finish at 4
            Originally posted by 50RTD
              Rear lower control arm supports came in mail yday, so will get them welded up tonight.
              Also got some silicone bends and pipe.
              Took the accelerator cable and pedal out. Wires everywhere for the aftermarket cruise will only use the buttons on the dash
                Barra looks so at home in there.
                Me rikey.
                  Originally posted by Milkman Don View Post
                  Im handy with a hammer, and also free tonight we can belt the cnt out of it.... I mean massage the tunnel to get the motor to sit properly.
                  For the forums knowledge are you going to upgrade the front anchors to VT spec?
                  I've got a whole VT brake kit to suit VS available if you're interested.
                  Originally posted by Marlin
                    Getting stuck into it, well done
                      Bahh, I just recently put new rotors and pads in it and it stops pretty good. Remind me when it's on the road
                      After work I picked up a valvespring tool from a mate, so that's one for tomorrow. Been playing around with the accelerator pedal to get an idea of how to do that. Turbosmart 14 psi actuator came but without a clevis, so need to sort that out. Tomorrow I drop ecu off to get vats removed and get a base tune with 60 lb injectors
                        Got el extension housing with Speedo gear today and also dropped off ecu for get vats removed and base tune with 60lb inj.
                        Adj upper rear control arms came in the mail and also bought some turbo studs/nuts from ford. Ford didn't have the output shaft Speedo gear so ordered that online
                        Started doing valvespring swap. Tricky suckers
                          Valvespring swap done, injectors done, block off front steam port done, new head temp sensor done. Cut the dump ready to rotate and weld. Also cut small hole behind headlight for intake side cooler piping.
                            So when you remove the extension housing from the BA trans, does the output shaft have whatever groove/slot etc that is required to mount the vss drive gear?
                              It's supposed to mine didn't. Cunt. So will try drilling it with carbide drill bit
                              Use the el housing with gears as above
                                loving the frequency of updates.
                                I was asking the guy who tuned our falcon about those adjustable actuators as straight off the actuator car is running 18psi and he suggested not getting them because something about them having less travel than the factory one and not opening far enough. i dunno how true that is but maybe something you could look at if you could be bothered.
