Talk to me about Saabs .. and Volvos
    Originally posted by I'm DJ! View Post
    Now to get the British junk out the way so I can use the hoist.
    Is there a thread on the British junk?
    230SL 'Pagoda' | 911 SC Targa | FC RX-7 Infini
      I think lost in the forum borking. There were a few pics in the jaaaaaaaaaaaag thread.
        Nice to see that the P1s weren't the only Volvo to have gear shift issues with the autos haha! Also an easy, but fiddly fix.
          These have a loooooong intake tract post turbo. The design goes from turbo out let over the gearbox and down to the bottom of the vertical intercooler. This apparently helps prevent ice build up on the bottom of the intercooler in cold climates. It goes up through the intercooler and then comes outthe top where a radiator cap normally is and does 2 x 180 degree turns into the intake manifold.
          That's the factory route above. And here's the turbo outlet view.
          And where it snakes back into the intake manifold.
          Now the Swedish volvo tuners include snabb who do some lovely kits and charge accordingly. They worked out if you reverse the flow through the intercooler you pick up good response and better cooling in hotter climates. Their kits is pretty snoozy.
ID:	7255763 And this is a bit of a beater / daily and I'm trying not to spend money on cars due to divorce this was an unlikely purchase for several hundred AUD. Step in one of the super cool gents on ozvolvos who sold me some other stuff and then sent me this care package as it was his spare! Thanks Lloyd !
          Legend. So I spent the last hour swapping it all over which was a bit of a mission getting the old gear off, this went on perfectly. Super good kit. Will report back post road-test after dinner and kids.
          Upper
          And lower to intake manifold
            Hell yea. I love it when these simple mods work out.
              Me too Greg! This things sounds better. It has maybe picked up 300-500rpm of spool and interestingly about 1.5psi of boost. 5psi now everywhere, super good midrange, even the auto bothers me less now!
              Next is suspension, maybe this weekend.
                Rear suspension:
                So I went with a fairly standard street setup of Sachs shocks and h and R progressive rate springs along with top hats and new bump stops as I assumed mine were going to be stuffed.
                With the car jacked off the ground first spray some penetrant on this strut bolt and also the captive nuts underneath the top hat and grab a cuppa.
                Click image for larger version  Name:	image_125025.jpg Views:	62 Size:	1.56 MB ID:	7256282
                If these seize then there is a bit of a drama as you then have to drill and tap and re weld a captive nut underneath. Fortunately mine weren't rusty.
                Click image for larger version  Name:	20210529_113907.jpg Views:	60 Size:	1.95 MB ID:	7256283
                Next up expose the strut tops so you can undo the top nut.
                The rear floor and boot seats need to come out to do this. Undo these 4 bolts, 2 per side.
                Click image for larger version  Name:	20210529_121535.jpg Views:	60 Size:	2.66 MB ID:	7256284 then slide the seat/floor forwards to release the clips then drag it backwards and out of the way.
                Click image for larger version  Name:	20210529_122439.jpg Views:	60 Size:	2.58 MB ID:	7256285 With the car back on the ground, now you need a 7 mm ring spanner or multi grips and a 15mm spanner, hold the shock top with the 7mm spanner and undo the nut almost all the way.
                Lift her back in the air and put a jack or jackstand under the spring perch and lower the car down until you get some tension off the strut. Undo the strut lower bolt and remove the top nut. Compress the shock and pull it off.
                Click image for larger version  Name:	20210529_124704.jpg Views:	59 Size:	2.71 MB ID:	7256287
                And it comes straight out. This looks to be 200000kms old. I reckon it's original.
                Click image for larger version  Name:	IMG-20210529-WA0007.jpeg Views:	60 Size:	1.28 MB ID:	7256288
                Now undo this nut under the spring perch which holds the spring seat in place and push it up into the coils. It's 15mm.
                Click image for larger version  Name:	20210529_130301.jpg Views:	59 Size:	1.99 MB ID:	7256289
                you can see it sitting here.
                Click image for larger version  Name:	20210529_130407.jpg Views:	62 Size:	1.64 MB ID:	7256290 now lower the jack all the way and I used a crow bar just to lightly pull the bottom of the spring free. Don't even need spring compressors, it just comes out.
                Click image for larger version  Name:	20210529_130719.jpg Views:	59 Size:	1.85 MB ID:	7256291
                That bump stops are cactus. Remove the rubber dust jacket, bump stop seal and pull the bump stops out so you can get the spring retainer out as both the retainer and seal will be reused. I re-greased the rubber grommet.
                Click image for larger version  Name:	20210529_131015.jpg Views:	62 Size:	1.20 MB ID:	7256292Click image for larger version  Name:	20210529_131114.jpg Views:	60 Size:	1.20 MB ID:	7256293 new vs old bumpstop
                Click image for larger version  Name:	20210529_131023.jpg Views:	62 Size:	1.11 MB ID:	7256294 and all back together. It goes back onto the top centre locating thing and slides in. Put the thread through the spring retainer and make sure the locating pin is in its hole and use the jack to compress it a bit to do the bolt back up. Springs done.
                Click image for larger version  Name:	20210529_131242.jpg Views:	61 Size:	1.42 MB ID:	7256295
                Locating thing.
                Click image for larger version  Name:	20210529_133509.jpg Views:	60 Size:	1.30 MB ID:	7256296
                Now replace the top hats, insert the struts and put the top bolt on and bottom and button it all up.
                Click image for larger version  Name:	20210529_131505.jpg Views:	62 Size:	1.37 MB ID:	7256297 except that the bolt that came with the strut is different and didn't feel like it had seated. It was moving laterally and I'd thought we'd done something wrong.
                Click image for larger version  Name:	20210529_141104.jpg Views:	62 Size:	2.54 MB ID:	7256298
                Looked at the old oem bolt and you can see it has a shoulder and this holds the strut bolt centred.
                Click image for larger version  Name:	20210529_142717.jpg Views:	62 Size:	1.87 MB ID:	7256299
                Back together, and it feels great. The front is ropey now in comparison!
                Ride height is about where it was too.
                Click image for larger version  Name:	20210529_150030.jpg Views:	61 Size:	3.22 MB ID:	7256300
                  Cool build thread is cool. Good work
                    Thank you sir ( sir = non easily identifiable gender specific named member ), did you used to be another name and if so what did you do? Or if you chose it, very creative!
                    Anyway, no sooner was this giving me feels in the arse end for the first time but it's now got an ignition issue, dammit... these are the bits I haven't bought as I thought they were solid. So now on the investigation list is
                    Rotor
                    Distributor
                    Coil
                    Then leads and plugs.
                    Just when it was starting to be really fun too.
                      man this is coming up millhouse! can you chip or flash this?
                      i await the for sale thread so i can make a purchase.
                        Thanks Sloth, it's hilarious fun now, I don't think it'll need much more power, it just bakes a wheel or both at anything under 60kmh. Makes me laugh everytime I step on it.
                        Which I can do now again. Because as per my last post, for 3 days now it's been running like a bag of Dicks.
                        I had 15 mins spare today and Steve at glt car centre had everything I needed in stock and said it's most likely the rotor button but to do the dizzy and leads and plugs as well.
                        It's here so the air box and maf needs disconnecting, and my new intercooler hard pipe needs to come off to get to the spark plug valley.
ID:	7256842 there's 3 x 8mm slotted grub screws holding it on and I needed a small spanner to crack them.
                        The rotor looks pretty worn down and the dizzy cap has seen better days too.
                        Make sure you notate the lead position as the no 2 and no 4 are the same length. For the Volvo t5 series being c70 v70 and s70 as well as 850r from 93 to 1999 this is the same firing order.
                        Plugs went in next. These are apparently quite sensitive to plugs and these are what the Volvo specialist local to me recommended even though the forum regulars use ngk's , these are a Bosch item, and pretty funky design! They are pre gapped so no need to do anything other than rub a bit of copper grease to keep them from binding.
                        They have 4 anodes.
                        The old plugs were probably due to come out anyway but none were broken.
                        All sorted and grin factor is back
                          Decided to tackle the front suspension today, trying to get some bonding going on with Mr teen.
                          Click image for larger version  Name:	20210605_083446.jpg Views:	31 Size:	2.25 MB ID:	7258594
                          Put your back into it to crack them
                          Click image for larger version  Name:	20210605_084515.jpg Views:	31 Size:	2.18 MB ID:	7258595
                          now you can have the rattle gun..
                          Click image for larger version  Name:	20210605_085106.jpg Views:	31 Size:	2.24 MB ID:	7258596
                          He was pretty excited about using the hoist. And lost interest shortly thereafter.
                          Undo these top bolts, 13mm.
                          Click image for larger version  Name:	20210605_111824.jpg Views:	31 Size:	2.29 MB ID:	7258597
                          Then the knuckles. Release the abs sensor and swaybar endlink and pull her out.
                          Click image for larger version  Name:	20210605_111831.jpg Views:	31 Size:	2.01 MB ID:	7258598
                          so far so good. Oh these are Sachs too. Wish I'd known, they don't look super old.
                          Click image for larger version  Name:	20210605_095242.jpg Views:	31 Size:	2.99 MB ID:	7258599
                          Anyway, crack on, stuff to do, looks like the new ones will need to be drilled for the abs sensor. Annoying.
                          Put the spring tensioners on. Undo the top bolt, 22mm, exposing this cross nut.
                          Click image for larger version  Name:	20210605_095832.jpg Views:	31 Size:	2.29 MB ID:	7258600
                          Then using a punch tap it off. I was told to reuse the bumpstops and bumpstop cover plate along with the dust jacket. The rubber spring perch and top mount are new.
                          Click image for larger version  Name:	20210605_095949.jpg Views:	31 Size:	2.94 MB ID:	7258601
                          Swap these onto the new strut, decompress the old springs, compress the new h&r springs and slide the new upright into the spring. Put the rubber spring perch on and...wait. compress some more. Nope. Wtf. Compress some more. Tell son to keep away from the spring, sweat whilst trying to do it up really tight. .. this ain't right. Remove spring, compare shocks. Fuck, there's my 20mm....
                          Click image for larger version  Name:	20210605_104153.jpg Views:	31 Size:	3.50 MB ID:	7258602
                          confirm they are a p1 chassis shock not a p80. Make decision to stick with the Sachs touring shocks which look maybe 10 or 15 thousand kms old. Transfer everything over to old shock. Reverse procedure and reinstall.
                          Cooking with gas now! Do the drivers side and get it all swapped and buttoned up. Look at it. Take a picture to look up online. It doesn't look right. Reinstall it anyway whilst waiting for a volvo mate to ring me.
                          Him: put the little little end on the smaller strut mount.
                          Me: wtf, I put it in the way the logos on the springs go.
                          Him: wtf, I don't think that's right.
                          Me: it's seated right, just the upper spring perch looks wrong. See.
                          Click image for larger version  Name:	20210605_124230.jpg Views:	31 Size:	1.61 MB ID:	7258603
                          Him: is that the little little coil end? It doesn't look right.
                          Me: is little little English? I put the tighter coil at the top, how the text and logos on the springs sit so you can read it when it's on the car. See
                          Click image for larger version  Name:	20210605_131037.jpg Views:	31 Size:	2.05 MB ID:	7258604
                          Him: yeah, that's confusing. Definitely put the tighter coil on the bottom.
                          Me: f@%$^#&ing cars cunts
                          My son by this stage, dad what are we having fir dinner...we started at 9am.
                          So.
                          Repeat, pull them out, undo the struts again, swap the springs around. Done. New ride height in shade, old in light. Probably only 1inch lower but it looks right. Feels better too, actually more supply than with the old flogged springs.
                          Click image for larger version  Name:	20210605_161500.jpg Views:	31 Size:	2.78 MB ID:	7258605
ID:	7258705 another angle with the new fronts below
                          Then sorted the old man's jag out and put his shit back in his shed.
                          Click image for larger version  Name:	20210605_163954.jpg Views:	31 Size:	3.29 MB ID:	7258606
                            Lolvo looks extremely good! What are these P1 shocks...?
                            Also, old man's Jag looks very fucking cool! Details?
                              Am on the search for some wheels. Volvo type r pegasus wheels would be perfect or something like an xt7 which look similar. See how the fun account goes.
                              Re the old man's e he has one of these (this picture is his car) : https://www.concours.com.au/recreati...ype-recreation
                              3.8 alloy billet block, wide angle c&g head, e85 , 400hp at crank, 900 ish kgs.
                              And one of these: https://www.concours.com.au/recreati...rag-recreation
                              4.2 , haltech, t56, air con 200 rwkw at 5850rpm approx 1000kgs.
                              On the lolvo it's so funny to me that a large car like the v70/850 is such a small car today. Sure its a fair bit longer but here she is next to a Mitsubishi colt 🤣
                                when i was a yoof, i regularly got pulled over by these, so i recokon you should make a replica.....
