Played around with routing brake ducting, the remainder of the OEM under trays has good positioning and locations for all this so I was happy with that
Pulled the 5 speed auto and threw that in the bin, the sump plug was stripped and stuck so I gave it the send off it deserved by drilling speed holes to get the fluid out
I've mostly wired up the gearbox now, internal mechatronics are done, everything appears to be in order
Mechatronics all sealed back up
Some weld needed to be added and a hole drilled then tapped to suit the M54B30 starter on this bellhousing
New flywheel/DCT Mandrel installed on the motor and rear main replaced
Started doing the GCU wiring however I found my crimper is no good for these Molex CMC/CMX connectors, I gave up before I munted too many and am now waiting on the correct tool.
Test fitted the shifter in the cabin, might need to make a longer shaft, I also need to design and print a facia to pretty it up a little.
Gearbox will get physically bolted in tomorrow, from there I can take measurements for the driveshaft and give that to the driveshaft place, and the diff can come back out to be sent off for the LSD install. During this downtime I'll finish the GCU wiring and hopefully get the gears changing and learn that all my wiring and soldering was done correctly. If it all works the box will come back out to have potting compound installed over all the wiring and solder joints.
