If you had to pick front or back on a live axle 4wd which would it be and why ?? I would go front as most difficult rocks and ledges you need a locker to pull you over and not push you into it harder.
1 locker only , would it be front or back ???
Rear all day long. 9 times out of 10 the rear is more loaded up with more weight on it and needs the most traction. The front generally has a lot less weight on it and therefore can not provide the same level of traction.
Sent from my SM-N960N using Tapatalk
Originally posted by BabalouieGeez we're a bunch of softcocks...we have a 911 and we're obsessing over non-functional ducts and indicator colours
Depends, on live axle with zero traction control I would go rear locker
Why? Because my current live axle 4x4 (P38 rangie) with traction control only on the rear doe not struggle one bit going up most shit, I can feel the TC kicking in A LOT but it walks up anything. The front axle is connected to the rear via a viscous coupling diff where you need some slip to heat up the silicon in it to lock it up, very very few times it locked but when it did you can feel it, without locking it up the fronts have about 10% torque. I have disabled the TC and tried to go up the same hill and viscous coupling kicked in very quick and got all 4 wheels going and pulled me up the hill.
So without any sort of TC I would first go locker on the rear, if you do have any sort of TC then locker on the front, specially with IFSOriginally posted by BeverlyHillsCopI think u should marry her... slip the ring inside your ass and next time she goes in, she'll come out with a ring on her finger...
Originally posted by irsa76 View PostLocker in the rear, a front locker compromises steering to much. There's a reason most factory lockers are in the rear only, and in the case of twin lockers the rear must be engaged before the front.Originally posted by BeverlyHillsCopI think u should marry her... slip the ring inside your ass and next time she goes in, she'll come out with a ring on her finger...
I would also add that i would run a cheaper auto/mechanical locker in the rear, but would prefer a more expensive selectable locker in the front so you can disengage to get steering back. So if your on a budget can get into a rear locker cheaper. I would not run an mechanical locker on any auto hub equipped vehicle in the front.
The ONLY time I would consider front locker before rear is if the vehicle comes factory with a very good rear LSD and that LSD can nit be moved to the front.
Last edited by vet 180; 22-11-20, 07:29 PM.Originally posted by BabalouieGeez we're a bunch of softcocks...we have a 911 and we're obsessing over non-functional ducts and indicator colours
Originally posted by XFJET View Post
usually you'd go lock the center, lock the rear and then lock the front then winch yourself out
Personally I'm not really a fan of lockers, I find good LSD to be much better in 99% of usage. To the point I'd love to rip the factory locker out of my Challenger and fit the Mitsubishi hybrid LSD in the back. For my usage the locker is a waste of time. On the other hand, I use the lockers in the truck all the time.
Mechanical self locker rear, helical if you are soft (they are nicer on road if your weight distributionis ok) and want to feather the handbrake occasionally. Electric in the front after mech rear only if it is really nasty.
You need to consider the front:rear weight distribution and relative roll stiffness of each end if you are forced to follow the question strictly. For most dual cabs with rear leaves you are likely to get max tractive effort with rear first, as they will take the most weight off a rear wheel from the already lighter end.Last edited by Slides; 22-11-20, 08:30 PM.
I like the Range Rover electronic gizmos compared to lockers, if you look at some L322's videos they are simply amazing off-road, they go up shit that most land cruisers and patrols with 3 diff lockers spin all four and "give it all she's got mate" while the rangie just uses electronic gizmos and slowy gets up without much fanfareOriginally posted by BeverlyHillsCopI think u should marry her... slip the ring inside your ass and next time she goes in, she'll come out with a ring on her finger...
It might very well depend on the car, but the two very capable units that i've driven (one IFS, one solid axle) over many obstacles there was exactly 0 that you could get up with the front locker on that you couldn't also get up with just the rear locker on.
There was a small number of them that you could get up with just the rear locker on that you couldn't also get up with just the front locker on.
tldr: rear .
