POLL : ACL Hylomar or VHT Copper Gasket ?
    Just curious as to what others use/prefer
    20
    Hylomar
    70.00%
    14
    Copper Gasket
    30.00%
    6
    Neither - Stock.
      Same - Never had a problem
        Chemi-weld for sure
          Both good, so is coppercote, pick 1 & use it - no probs.
          (I use hylomar, only because it's the easiest for me to get)
          Cheers
          TK
            Where can i find hylomar?..... Local Repco?.
            Might look at using it as well in the future, although i've never had any problems in the past a little bit of extra insurance is not a bad thing
              +1 for hylomar because it's not copper.
              Copper gaskets are a bastard, I've never had a car with one but I did a bit of research and spoke with my cousin (drag car cousin, Sir Rev, not dropkick one :D)about it and unless it's made and fitted 100% correct you will have drama.
              That said I don't know anything about hylomar so it could be gheyer then a bus full of queens on the way to a gaol.
                If the block and head are o-ringed then it's fine to use copper, otherwise it might not seal 100%. That's what i've been told anyway.
                  Repco have it sometimes its not on show you just have to ask at the counter. Get a spraycan they also make a brush on option.
                  PM me for more info
                    Originally posted by carazy
                    Copper gaskets are a bastard...
                    Originally posted by 6.97
                    If the block and head are o-ringed then it's fine to use copper,...
                    The thread/poll is referring to VHT Copper Gasket (a spray on adhesive/sealant) as opposed a copper head gasket.
                    I bought Hylomar off the shelf at Repco. Wasn't a successful solution to my application, which was basically a result of poor design/fabrication that no amount of spray on sealant was going to fix.
                    EH Holden RB20 Build
                      Gotcha.
                        Gotcha.
                        x2
                          Used Hylomar spray on headgaskets for years and never had a prob. Cept when I worked at Honda and we used proper Honda metal headgaskets (they are the schnit!).
                          2004 Nissan El Grand rape van
                          2007 Suzuki SX4 - Ski Mule
                          2005 WR250
                          + 2 trailers and a caravan.
                          I finance the RMS
                            Just a note, I only recommend using a sealant on MLS or copper gaskets, composition gaskets should be fitted dry.
                            ('cept the real old style composition gaskets - but no-one uses them unless there is no other choice)
                            Copper head gaskets are shit in 95% of applications, they are a poor stop gap solution that will almost always give trouble & should be avoided if at all possible.
                            Cheers
                            TK
                              Yes i was referring to both as a spray on aerosol product , i use them regardless of manufacturers instructions , as someone said , just as insurance.
                              Ohh btw both products can be obtained from Coventry Auto Parts
                              I personally hate repco , never buy anything off them ...
                              REPCO - Rip Every Poor Cunt Off
