wow, are they HRE wheels still in one peice?
Tt E60 M5
If cost weren't an issue why not mount the big one in the engine bay off a nice short manifold and have it feed a 12-71Originally posted by LoTeCnot if you have the small turbo's going as per normal (cept with a 1way bypass valve) and the big turbo can just come on whenever it feels like it.
Not sure why the 5miles of pipe matters? the lag is (relatively) gone, and in my example cost is not an issue
Originally posted by The PupatIf cost weren't an issue why not mount the big one in the engine bay off a nice short manifold and have it feed a 12-71
cuz the guy in my example wants to do it this way
i'm not saying it would be the easiest option, but mechaincally speaking, it would work right?
Turbos look like crusty old T3s or something?I've seen things you people wouldn't believe, and from this side only! The flight of a half-man, half-bird. Dinosaurs nuzzling their young in pastures where strip-malls should be. Cookies on dowels. All those moments lost in time; gone like eggs off a hooker's stomach. Time to die.
- Phil Ken Sebben
I understand this totally.Originally posted by edoDont have to...the whole reason you shorten the inlet tract as much as possible is to get better response.
If this was so awesome then race cars would run 20 metres of pipe all over the car just to make the inlet tract as long as possible...rather than doing the opposite.
If you dont understand this then there probably isnt much chance of anyone explaining it to you.
however the cost is probably at least 1/2 of a normal conversion - but without comparison, we can all just say "yeah that sux, and wont be as good". would that money be better spent, on say 30" chromies
pop the bonnet with a rear mount, and its like "what turbo officer"
Originally posted by psssi98I'm not down for crossing swords in the mud. :p
Why? They have to custom make 5+ metres of piping per turbo, including lots of nice bends which fast flowing air loves negotiating, get oil/water lines to the turbos (separate reservoirs/pumps? $$) etc. Am i missing something?Originally posted by GHaSThowever the cost is probably at least 1/2 of a normal conversionKate Beckinsale to divorce and marry me.
I saw a VX SS at the summernats with this setup with the mandatory meatheads crawling all over it in the traders pavilion. I just kept asking myself why and couldn't come up with one good reason as surely theres enough room in the engine bay for one if not two turbos.
Too be honest its like something an american would do.RB26......................Again
Got a point there. it may be cheaper to do this piping (as apposed to manifold) - but there is a lot of it to make up for it.Originally posted by govichWhy? They have to custom make 5+ metres of piping per turbo, including lots of nice bends which fast flowing air loves negotiating, get oil/water lines to the turbos (separate reservoirs/pumps? $$) etc. Am i missing something?Originally posted by psssi98I'm not down for crossing swords in the mud. :p
That show on Foxtel, Two Guys Garage, did an install of one of those under-boot turbos on an F-Body Camaro. It was a bloody quick install, basically you drop the muffler, then the turbo and associated plumbing just bolts on in its place, using the stock hangers and all.Originally posted by CussCussi have no doubt it would be laggier but how much laggier is the question.
If you size down on the turbos slightly then you should be able to compensate for that lag.
How fast does exhaust gas flow, etc....
Power went from 260 to 390hp at the wheels (on a Yank dyno, mind) and they went to some pains to point out that full boost came on by 2000rpm and lag wasn't an issue.Japanese Nostalgic Car - Dedicated to classic japanese cars
I'd love to see what they come up with if asked to do a comparison of response with the same engine/car and the turbo in the engine bay. It's like running a rear mounted T25 fed by an LS2 and prancing around boasting full boost at 1500rpm, in an attempt to prove that there is no noticeable lag introduced by adding 5x the amount of piping and bends.Originally posted by Babalouiethey went to some pains to point out that full boost came on by 2000rpm and lag wasn't an issue.Kate Beckinsale to divorce and marry me.
