Ring Competition Friction and ask for Marty. He races an 8 and sells all different kind of brake stuff. He might have some spares.
Evo 4+ rear cut
(TM - AVENGE)
Find out what the new parts are worth and compare?"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower." - Mark Donahue Penske Porsche 917
(TM - AVENGE)
true, but the other consideration is the intended use. If I am to release the plans for Godiva and the build life might be 3 years, then those that decide to join the madness will be looking for an older part that will be increasingly hard to source.
The Evo 8 I had a look at also seemed to have the same splines in the hub as the 380...this will seal the way to go if true. As you know it is not easy to find evo bits sitting on the shelf all over the place.I don't care a damn for your loyalty when you think I am right; when I really want it most is when you think I am wrong.
Sir John Monash
