Where the hell do I buy this stuff from? All hardware stores are normal steel, this is to go in a catch can. I done some searching and they use stainless in mufflers etc but dunno where to get it by its self
Cheers
3D scanning
3D modelling
Structural certification
3 and 5 axis milling
There is usually a few different brands there, and they have written on them if they are stainless or not.
Usually the stainless stuff looks very 'curly' like swarf from a drill, whereas the normal stuff is like cotton wool balls made of metal.
Originally posted by jmac
But on seatbelts - I don't think they should be mandatory for adults, but for under 18s. I reckon make them mandatory up till then, and provide plenty of graphic evidence supporting their use to school age children, and then if they hit adulthood and don't choose to wear them, think of the future without these fucken idiots around...
I have a shitload of stainless steel shavings from making washers on the lathe? could that help?
Originally posted by Marv
PLAYA,
Try Bunnings , Mitre 10 etc and look in the cleaning section. They usually have bulk packs of these things aimed at cleaning companies , builders and other tradies etc.
Is this for an air / oil spearator can?
If it is I got a box from my local AMWAY distributor called "Scrub Buds"
