I assume they are the same mount. What is the cheap fix? Toyota wants some ridiculousness price. I heard there is an aftermarket one, or a Holden one you can mod to fit?
Any ideas?
10.83 @ 125
Originally posted by cracka
Toyota Part Number 12360-46111 from the 98 VVTi Supra Fits and functions very well, with very minor modifications. Just a small bit of drilling the subframe mounting slot/hole from the
existing 12mm to 14.5mm, (5 minutes work) and buying 2 M14
nuts and 6 flat washers, bring the mount to thread them on to
check and be sure, as the lower mounting attachment is of a larger diameter.
This is an upgrade above the strength of the original Aristo items
It has similar strength to the TRD item, as they are both of a
similar philophosy of construction.
