Urgent Help Needed!
    well, one side of the ballast resistor runs away on the other side of the car to where i cant see it. The other point used to go right to the MSD, then the MSD would go to the Coil.
    So does the point that used to go to the MSD now need to go to the Positive (+) part of the coil?
    Would this be causing it not to spark? I just cant figure out why it has power but wont spark ><
    Past
    74 260z - MOBY
    00 WRX - JARVIS
    93 Rz Supra - SOUP
    05 Golf GTI
    07 350z Track
    73 240z - Red Car
    13 BRZ
    04 Liberty GT
    10 ISF
    Current
    91 SW20 MR2
      What are the voltages on the + and - side of the coil?
      If they're both at ~12v, then all you need is the points to earth out the - side of the coil, and bolts of lightning will ensue.
      Alex.
        thanks! thats exactly what i needed to hear.
        Ill check the points
        Alex your a life saver
        Past
        74 260z - MOBY
        00 WRX - JARVIS
        93 Rz Supra - SOUP
        05 Golf GTI
        07 350z Track
        73 240z - Red Car
        13 BRZ
        04 Liberty GT
        10 ISF
        Current
        91 SW20 MR2
          dude I'm no expert but based on other setups I've seen I don't think you need to run a ballast resistor with an MSD, fairly sure they're designed to run on the full 12v. Perhaps this caused the problem?
          1965 Valiant AP6 Regal Safari 318, 1977 Chrysler Charger 265 - SOLD
          Web design and development on the South Coast of NSW - PF discounts, pm me
            Ballast resistor is a common old factory hatchet job to increase the life of the ignition coils and I think points by limiting current to the coil.
            PM me for more info
              ah righto, I always thought it was to my ignition ecu.. cheers.
                My
                Spark
                Died
                  Whether or not you run a ballast resistor depends on the coil used. For example, the Bosch "R" series coils (designed for use with a ballast resistor) have a lower impedance to the "non R" series coils. Without a ballast resistor, the R series coils may fail prematurely. They are specifically designed to provide a better spark when the resistor is bypassed while the engine is being cranked over and the battery voltage may be reduced.
                  James
                    Do you still have the condenser across the points? The body of the condenser is usually bolted to the coil mounting bracket and there will normally be a single wire coming out of the condenser that connects directly to the coil -ve terminal?
                    James
                      Yup thats still sitting there snugly.
                      If the points dont fix it i know of a Electronic Dizzy thats pretty cheap.
                      But all the same my mate cant keep driving me to work and back.
                      Let hope its the point.
                      P.s Edo
                      ha....ha
                      Past
                      74 260z - MOBY
                      00 WRX - JARVIS
                      93 Rz Supra - SOUP
                      05 Golf GTI
                      07 350z Track
                      73 240z - Red Car
                      13 BRZ
                      04 Liberty GT
                      10 ISF
                      Current
                      91 SW20 MR2
                        You can also check that the points function electrically by disconnecting the wire to the - side of the coil, and using an ohmmeter between the points connection and ground.
                        Turning the engine over (by hand) should result in the ohmmeter showing no connection when the points are open, and a closed circuit when they are shut.
                        If this isn't happening, then you won't get spark.
                        Alex.
                          Alex.
                          ... and while you're at it, disconnect the points, and make and break an earth connection to the coil's -ve terminal and see if the coil will produce a spark when the earth connection is broken. If it doesn't, and you have power going to the +ve terminal of the coil, then your coil is stuffed.
                          James
                            Call a tow truck.
                            CJM 4 Life yo!
                              I did call a tow truck its at a mates place now.
                              Ok turns out i blew the coil by hooking it right up to the battery instead of the ignition via the ballast resistor.
                              So i had 12V going in, and 12V at the Dizzy, but nothing coming to the main lead into the Dizzy.
                              Points don't look too bad, ill clean a little bit of build up off them but im thinking if the car died on the spot after being turned off, its more likely something just failed, and i dont see all the points doing that at once. But who knows, well see once i put the new coil on and hook it up properly
                              Past
                              74 260z - MOBY
                              00 WRX - JARVIS
                              93 Rz Supra - SOUP
                              05 Golf GTI
                              07 350z Track
                              73 240z - Red Car
                              13 BRZ
                              04 Liberty GT
                              10 ISF
                              Current
                              91 SW20 MR2
                                It might have been the coil that failed originally.
                                Alex.
