Header / Extractor design
    simon, here's the rest:
    no. of intake valves 2
    valve head diam 35mm
    valve stem diam 7mm
    cam valve lift 7mm
    duration at seat timing 262
    degreed centreline / lobe centreline 113
    exhaust:
    no. valves 1
    valve head diam 41mm
    valve stem diam 8mm (? from memory)
    cam valve lift 7mm
    duration at seat 264
    centreline length don't know how to work out
    header type 4-1, with straight or tapered collector.
    thanks
      btw, is pipemax worth buying? fairly accurate?
      I know Larry Meaux certainly knows his stuff, just wanted feedback from people who actually use it.
      Ordered Scientific Design of Intake and Exhausts through Amazon last night, out of stock but they are ordering it in. $33 AUD delivered (standard 11-16 day shipping), pitstop.net.au want $68 + shipping for the same book!
        --- Single Primary Pipe Specs --- for 145.683 CID from 4250 to 6750 RPM
        Diameter= 1.510 Length= 36.8 to 39.6 also 25.8 to 28.6 inches long
        Note> Maximum Primary's Tuned Length= 61.0 to 63.8 inches long
        --- Header Collector Specs (Conventional Straight Tube) ---
        Diameter= 2.801 Tuned Lengths= 19.6 best and 9.8 or 39.2
        H-Pipe= 19.6 X-Pipe= 78.3 distance behind end of Primary Tube ends
        -- Total Exhaust System Tuned Lengths (Primary ends to TailPipe end) --
        Best HP/TQ Tuned Collector Lengths= 19.6 , 39.2 , 78.3 , 156.6 inches long
        Worst HP/TQ Loss Collector Lengths= 29.4 , 58.7 , 117.5 , 234.9 inches long
        Note=> measured from where the Primary Pipes end inside the Collector to
        the point the tailpipe exits into the atmosphere.
        H-Pipe is located at end of Collector, and X-Pipe is located
        usually half-way between end of Primary Pipes -to- tailpipe end
        Note-> all Pipe Diameters are OD and based-off .0625 inch Pipe thickness
        ---- Primary Pipe's Harmonics ----
        1st Harmonic = 159.7 inches long ... typically never used
        2nd Harmonic = 61.0 inches long ... longest recommended
        3rd Harmonic = 36.8 inches long ... highly recommended , best Torque Curve
        4th Harmonic = 25.8 inches long ... shortest recommended
        5th Harmonic = 19.6 inches long ... typically never used
        6th Harmonic = 15.5 inches long ... typically never used
        7th Harmonic = 12.7 inches long ... typically never used
        8th Harmonic = 10.6 inches long ... typically never used
        ---- Collector's Harmonics (includes Intermediate, Muffler , TailPipe) ----
        1st Harmonic = 156.6 inches long ... longest with Mufflers and TailPipes
        2nd Harmonic = 78.3 inches long ... longest recommended with Mufflers
        3rd Harmonic = 39.2 inches long ... more bottom-end Torque
        4th Harmonic = 19.6 inches long ... highly recommended , best Torque Curve
        5th Harmonic = 9.8 inches long ... reduced Torque , more top-end HP sometimes
        6th Harmonic = 4.9 inches long ... reduced Torque , not recommended
        ************** Metric Units ******************
        --- Single Primary Pipe Specs --- for 2.387 Liters from 4250 to 6750 RPM
        Diameter MM= 38.366 Length= 933.5 to 1004.7 also 655.5 to 726.7 MM long
        Note> Maximum Primary's Tuned Length= 1548.6 to 1619.8 MM long
        Diameter MM= 71.148 Tuned Lengths= 497.3 best and 248.6 or 994.5
        H-Pipe= 497.3 X-Pipe= 1989.1 distance behind end of Primary Tube ends
        Best HP/TQ Tuned Collector Lengths= 497.3 , 994.5 , 1989.1 , 3978.2 MM long
        Worst HP/TQ Loss Collector Lengths= 745.9 , 1491.8 , 2983.6 , 5967.3 MM long
        Note-> all Pipe Diameters are OD and based-off 1.588 MM Pipe thickness
        1st Harmonic = 4057.1 MM long ... typically never used
        2nd Harmonic = 1548.6 MM long ... longest recommended
        3rd Harmonic = 933.5 MM long ... highly recommended , best Torque Curve
        4th Harmonic = 655.5 MM long ... shortest recommended
        5th Harmonic = 497.0 MM long ... typically never used
        6th Harmonic = 394.7 MM long ... typically never used
        7th Harmonic = 323.1 MM long ... typically never used
        8th Harmonic = 270.2 MM long ... typically never used
        1st Harmonic = 3978.2 MM long ... longest with Mufflers and TailPipes
        2nd Harmonic = 1989.1 MM long ... longest recommended with Mufflers
        3rd Harmonic = 994.5 MM long ... more bottom-end Torque
        4th Harmonic = 497.3 MM long ... highly recommended , best Torque Curve
        5th Harmonic = 248.6 MM long ... reduced Torque , more top-end HP sometimes
        6th Harmonic = 124.3 MM long ... reduced Torque , not recommended
        have fun
        Simon
        Originally posted by RotaUte
        I take it you're a PF member by the gay sarcastic comment that I'm sure you thought
        was funny after 2 beers, but it was lamer than possibly recordable.
          Any chance for one as well.
          VE approx 95%
          Bore 3.18 (81mm)
          Stroke 3.03 (77mm)
          Rod length 4.8 (122mm)
          Cyls 4
          Peak hp rpm 8500
          comp ratio 12:1
          valve head diam 32mm
          valve stem diam 6mm
          cam valve lift 9.65mm
          duration at seat timing 308
          degreed centreline / lobe centreline 152
          exhaust:
          no. valves 2
          valve head diam 27mm
          valve stem diam 6mm (? from memory)
          duration at seat 308
          Cheers
            Is that right?
            Thats pretty wide.
            Simon
              I entered 110 as lobe sep and got this:
              --- Single Primary Pipe Specs --- for 96.260 CID from 6500 to 9000 RPM
              Diameter= 1.416 Length= 29.3 to 31.8 also 20.4 to 23.0 inches long
              Note> Maximum Primary's Tuned Length= 48.9 to 51.5 inches long
              Diameter= 2.638 Tuned Lengths= 15.0 best and 7.5 or 30.1
              H-Pipe= 15.0 X-Pipe= 60.2 distance behind end of Primary Tube ends
              Best HP/TQ Tuned Collector Lengths= 15.0 , 30.1 , 60.2 , 120.3 inches long
              Worst HP/TQ Loss Collector Lengths= 22.6 , 45.1 , 90.2 , 180.5 inches long
              1st Harmonic = 129.2 inches long ... typically never used
              2nd Harmonic = 48.9 inches long ... longest recommended
              3rd Harmonic = 29.3 inches long ... highly recommended , best Torque Curve
              4th Harmonic = 20.4 inches long ... shortest recommended
              5th Harmonic = 15.3 inches long ... typically never used
              6th Harmonic = 12.0 inches long ... typically never used
              7th Harmonic = 9.7 inches long ... typically never used
              8th Harmonic = 8.0 inches long ... typically never used
              1st Harmonic = 120.3 inches long ... longest with Mufflers and TailPipes
              2nd Harmonic = 60.2 inches long ... longest recommended with Mufflers
              3rd Harmonic = 30.1 inches long ... more bottom-end Torque
              4th Harmonic = 15.0 inches long ... highly recommended , best Torque Curve
              5th Harmonic = 7.5 inches long ... reduced Torque , more top-end HP sometimes
              6th Harmonic = 3.8 inches long ... reduced Torque , not recommended
              --- Single Primary Pipe Specs --- for 1.577 Liters from 6500 to 9000 RPM
              Diameter MM= 35.954 Length= 743.2 to 808.9 also 517.3 to 583.0 MM long
              Note> Maximum Primary's Tuned Length= 1242.9 to 1308.6 MM long
              Diameter MM= 67.016 Tuned Lengths= 382.0 best and 191.0 or 764.0
              H-Pipe= 382.0 X-Pipe= 1528.1 distance behind end of Primary Tube ends
              Best HP/TQ Tuned Collector Lengths= 382.0 , 764.0 , 1528.1 , 3056.1 MM long
              Worst HP/TQ Loss Collector Lengths= 573.0 , 1146.0 , 2292.1 , 4584.2 MM long
              1st Harmonic = 3280.9 MM long ... typically never used
              2nd Harmonic = 1242.9 MM long ... longest recommended
              3rd Harmonic = 743.2 MM long ... highly recommended , best Torque Curve
              4th Harmonic = 517.3 MM long ... shortest recommended
              5th Harmonic = 388.5 MM long ... typically never used
              6th Harmonic = 305.4 MM long ... typically never used
              7th Harmonic = 247.2 MM long ... typically never used
              8th Harmonic = 204.3 MM long ... typically never used
              1st Harmonic = 3056.1 MM long ... longest with Mufflers and TailPipes
              2nd Harmonic = 1528.1 MM long ... longest recommended with Mufflers
              3rd Harmonic = 764.0 MM long ... more bottom-end Torque
              4th Harmonic = 382.0 MM long ... highly recommended , best Torque Curve
              5th Harmonic = 191.0 MM long ... reduced Torque , more top-end HP sometimes
              6th Harmonic = 95.5 MM long ... reduced Torque , not recommended
              have fun
              Simon
                cheers simon, appreciate it.
                  Originally posted by XEFalconUte View Post
                  Do you have the book? I do and it does give good empirical formula to use in choosing pipe sizes, lengths, collector length and diameter.
                  Simon, which edition of the book do you have? i think i only have the first edition..
                    Is that right?
                    Thats pretty wide.
                    Simon
                    ooops, 112 is what i meant, brain fart. 110 will be close enough. Thanks heaps.
                      7th impression
                        One tid bit I'll add - if you are running a v8 - don't bother with a h pipe, run an x pipe, and be done with it. On the minus side, it tends to quieten the exhaust a bit, on the plus, it gives the best gain (and it's more in the mid range and across a wide rpm range than some focussed gain in peak power).
                        In terms of header design, I've found (in what experience I have, which isn't massive by racing standards) that all the theory in the world is good, but you'll still have to 'suck it and see' the more oddball the engine is in terms of port and or bore/stroke/rod length design and other factors, the more you have to experiment. Something like a sbchev - the work has been done in spades.
                        Are any of these books floating around as pdf files/torrents?
                        John McKenzie
                          Not the book your after but this might be interesting for anyone building exhaust systems, search for the torrent:
                          Working with Tubing (imburne).avi.torrent
                          have fun
                          Simon
                            FYI for anyone wanting to buy Scientific Design of Intake and Exhaust Systems through Amazon...don't. They can't fucking source the book at all.
                            Ended up getting it from pitstop.net.au for $63 incl express delivery, it's on sale at the moment.
                            That avi "working with tubing" is quite good.
                              Simon,
                              Do you still have pipemax?
                              I'm going to be making a set of pipes for my L98 soon, would you be able to run the numbers if I give you all the details?
                              Cheers
                              Peter
