4-valve v's 2-valve heads
    631ft-lbs @ 5100
    745 @ 6300rpm.
      627ft-lbs @ 5200rpm
      753hp @ 6400rpm.
      Yeah the original test was to keep the grunt down to around 600hp or so, and have a fat torque curve. We wandered a tad.
      Yeah I can get the valves in no probs.
        625ft/lbs 5500rpm
        740hp 6500rpm
        Agressive solid roller cam, still the same off the shelf heads, still pump 98
          We gonna call it pretty much even?
          I'll concede that the 4V does have a slight advantage in power delivery, you'd better concede that mine can be built with existing parts at a reasonable cost & will be more compact.
            Hmmmm I'm thinking we should perhaps be using the same program to make sure we're on the same page.
            What are you using?
              Seems fair.
              I don't know why the big engines don't get as much benefit from a 4V head as the small ones do though - if anything, it should be the other way around.
                Engine analyser pro.
                I figure you're using the same.
                  Yeah, it would seem that should be the case, but in real life it simply isn't so.
                  I ain't gonna try to match a 4V 1600cc 4-banger with a 2V tho, I'd get smashed.
                    Yep. Version 3.3
                    We should swap files ... ?
                      Yep, here's the next road engine I'm building.
                      A mate in Europe has actually built almsot exactly the same engine and it makes 248hp at the crank.
                        Yeah, ok, but I gotta figure out how the hell to find the file in order to send the damn thing.
                        Outta time, I'm 1/2 way to being screwed for the day now, gotta go finish machining a 350 chev & start popping a 4L for back together.
                        Ah, crap, why am I so easily distracted?
                          So as long as your dinosaur donk is big its just as cool as a new fangled big un?
                          Now get back to work on my donk TK
                            It should be somewhere here ->
                            ......\ean pro3\Users Total Engine Files\....
                            FWIW here's the 32v LS7.
                            http://www.billzilla.org/temp/LS7 DOHC
                              Cool, I'll find it - but I'll send a new one.
                              Just switched to an 8 deg style chamber:
                              772hp @ 6500
                              648ft/lbs @ 5500
                              I'll send you that one.
                                Ok, got the file, but can't do an attatchement using PF's email function, send me something & I'll shoot it over.
