If you guys want to work out why this is happening, just punch your various numbers in a spreadsheet and see what the ratios of bore diameter, area, valve head diameter, area and curtain area come out like.
I'm sure that the relationship between some of those varying as the square of bore (and valve) diamater, and some varying only linearly with bore diameter will paint an enlightening picture.
You will need to do it for the engines you have just done, and probably almost any pair of comparable 1.3 - 2 litre engines as well. Obviously the 2V small engine would want to be one that has a decent head - no dungers like the Kent.
cheers
cheers
