Originally posted by TK
View Post
re pumping.. the increased pull on the piston will be closer to mid stroke for the 2V, and the inertia effect will be near BDC, so the piston has less moment arm on the crank.. so it would still lose out on pumping losses..
edit: in sayin git takes longer time for things to happen for the 2V, that is saying "there is an upper limit to what rpm they can work at.
but to say that something that happens faster (4V intake) can't work at lower rpm seems backwards...
ie, if you have different burn time for fuel, then you adjust the time at which it ignites... but a fast burning fuel can still work at lower rpm.. it just needs less advance to reach peak cylinder pressure at the right time... whereas a very slow burning fuel, won7t completely burn if you go to high rpm
