Originally posted by TK
View Post
4-valve v's 2-valve heads
FFS people, read the damn thread, I ain't arguing it all again.
If you can get as much cylinder fill with a 2V as you can with a 4V on a certain engine in the rpm range that is required then there is no fucking advantage performance wise from running a 4V head - it's pretty fucking simple, the extra flow of a 4V is fucking irrelevant if it is not needed & can't be used.
Get it into your thick fucking skulls - an engine of xx capacity can only injest so much air - fitting it with heads that can flow more than it is capable of consuming is a backwards step in terms of velocity for no benefit whatsoever (in terms of performance).
Christ, it's not that fucking hard to understand, give up on the '4V is always better' religion - yes a 4V head is often a better idea, but under some curcumstances (ie. big fuck off V8's) there is just no benefit.
Fucking pinheads.
Yes I'm annoyed - if Bill can see that 4V's are not the be all & end all under all circumstances (& he is the most dedicated 4V fan that exists methinks) you would think that you lot would be capable of understanding it - or is it just that Bill does actually understand what is going on & you lot don't? -you're too stuck in the 2V is better world to look outside it.
No, I do not believe that 2V heads are better - that is blatantly not true, but I do have enought knowledge & experience to know that they can do a better job than most people think.
Bah, why bother, some people just refuse to think it through - their loss, understanding the thoery could help them better understand engines in general, but nope, easier to just bury yer head in the sand & chant 4V is best, 4V is best, 4V is best....
what?...is this directed at me. I asked a simple question based on your premise of 'unrestricted'. I HAD assumed you would know of a situation where this was the case and you could educate me, not spit the dummy.I don't care a damn for your loyalty when you think I am right; when I really want it most is when you think I am wrong.
Sir John Monash
Sorry Nero, not at you, look at Ze's post - he's argued the same things that have been already covered, some a few times & it shows that he has no understanding of the basic concepts or he can't read.
That's what pissed me off.
But there is not situation I can think of where larger capacity 4V & 2V engines compete in a comparable situation.
If 'unrestriced' means no rpm limit them a 4V of the same capacity is almost always gonna win - at higher rpm the donk can use the extra airflow.
The only situation I can think of is Le Mans, where the Corvettes have done so well...but they are not unrestricted...and have noting in common with road engines.I don't care a damn for your loyalty when you think I am right; when I really want it most is when you think I am wrong.
Sir John Monash
I can read and understand the basic concepts :p I just skipped a few pages :pOriginally posted by TK View PostSorry Nero, not at you, look at Ze's post - he's argued the same things that have been already covered, some a few times & it shows that he has no understanding of the basic concepts or he can't read.
Mate I'm not one of the people who bash 2-valve engines or say they are a waste of effort. I just like motors , doesn't matter if they are 2-valve , 4-valve , OHV or OHC or side valve.
However there is more to a cylinder head than just the amount of air it flows and the number of valves. I mean fuck you know this you reshape the combustion chambers and do other tricks to improve how it burns.Originally posted by TK View PostFFS people, read the damn thread, I ain't arguing it all again.
Alternatively I could be fucking wrong on this count and once you start flowing that much air it's all about flow and nothing about the piston shape , combustion chambers and valve shape. Feel free to tell me I'm completely off base if I am.
I wasn't arguing with that TK and I'd be a fucking bigger idiot than I think am if I did :pOriginally posted by TK View PostNo, I do not believe that 2V heads are better - that is blatantly not true, but I do have enought knowledge & experience to know that they can do a better job than most people think.Originally posted by Crash DummyI had reason to believe that the photo could have been of a very well done tranny. I have been fooled in the past
Go back & read, port velocity, swirl, chamber shape & burn characteristics are all covered back there somewhere.However there is more to a cylinder head than just the amount of air it flows and the number of valves. I mean fuck you know this you reshape the combustion chambers and do other tricks to improve how it burns.
I've run through the +'s & -'s of both designs, several times I think.
so cliffnotes:
if the engine is spinning slow enough, then both 2 and 4 valve can inhale enough air to get about the same VE.
once the engine is spinning fast enough to take advantage of intake harmonics/pulse tuning (whatever you want to call it), or gets over a certain RPM,then the 2 valve fall behind and can't match the airflow requirements?"I'm a retarded Doctor, not a retarded Mechanic"
Originally posted by TK View Post... or is it just that Bill does actually understand what is going on & you lot don't?
I don't entirely understand why yet, but I'm trying to and accept the evidence so far.
There's still the advantage of variable cam timing available on twin-cam heads, that is not possible on single-cam one - That alone can make quite a difference to to overall torque curve and it quite easy to fit & operate these days.
Yes, but whilst that advantage is inherent in the head design (in that you can add it because the head design allows you to) it is not inherent in the design.Originally posted by Billzilla View PostThere's still the advantage of variable cam timing available on twin-cam heads, that is not possible on single-cam one - That alone can make quite a difference to to overall torque curve and it quite easy to fit & operate these days.
If you guys can scrape together some more 2 valve engine bore, valve diameter numbers, across a range of bore sizes, I can continue to look at those ratios to see what jumps out.
cheersOriginally posted by bugleThe non GTS's were gay
Wouldn't exactly put it as 'spinning slow enough' - I'd guestimate the crossover point to be between 6-7000rpm on average, ie somewhere between 6-7000rpm the 4V will start to show a significant advantage due to superior airflow.if the engine is spinning slow enough, then both 2 and 4 valve can inhale enough air to get about the same VE.
^ that is a very broad statement tho, assumes both a good 4V & good 2V design that is matched well to the motor.
But it is - How would you move the lobe centre of the inlet cam compared to the exhaust cam on a single-cam engine? True enough it's easy to advance/retard an entire cam, but that has far less effect than being able to drastically change the overlap, etc.Originally posted by GTSBoy View PostYes, but whilst that advantage is inherent in the head design (in that you can add it because the head design allows you to) it is not inherent in the design.
I'll do that bunch of calculations I mentioned a while back on the single cylinder engines - It'll take a while as I'm really busy this week ..... and really lazy as well.Originally posted by GTSBoy View PostIf you guys can scrape together some more 2 valve engine bore, valve diameter numbers, across a range of bore sizes, I can continue to look at those ratios to see what jumps out.
cheers
I was going to say, it's not impossible. That is a good trick isn't it?
Even variations on Honda's first VTEC where you have extra lobes locked in by pins would allow you to have crude lobe centre changes between inlet and exhaust, and more lift too even in a dinosaur V8. Would need some differences in follower layout down in the valley.....
And an OHC 2 valver allows you to play with rockers and finger followers and all sorts of toys that can give you some tweakage as well.
It's just dead easy in DOHC by comparison.Originally posted by bugleThe non GTS's were gay
