An extract from my site, and yeah it's only a small engine blah blah blah but it's an example.
This is an extract from a friend of mine, Dave Andrews, about this very subject. He's what he had to say about some dyno runs that he did -
"First off I agree with most of what Bill has said, 4 valve engines simply allow better cylinder filling at all RPM, this translates to improved BMEP and therefore increased torque and BHP throughout the rev range. I would say that a 4 valve engine in aspirated form, developed properly will make about 90ft/lb per litre tops and can sustain most of this for around 50-55% of its rev range, an 8 valve engine developed properly will make no more than 82ft/lb per litre and can sustain most this for no more than 40-45% of its power band. This means that a stonking 4 valve engine will be far more flexible and have a wider torque envelope that an 8 valve.. end of story, where you choose to make that torque is up to you.
Effective cylinder filling at high RPM (and therefore big BHP) comes at a price on an 8 valve engine, the price is wild cams and lots of overlap, these destroy low down torque. 16 valve engines have inherently better cylinder filling because of increased valve curtain area, to extract greater power requires less cam duration and less overlap than with an 8 valve, this allows better retention of the engines low down torque characteristics.
I've run my current engine in 8 valve and 16 valve form, both times running relatively enormous cams (8v 326deg, 16v 302deg) with ultra big valve heads and 48 webers, the 16 valve version produces 70BHP more and comes on cam 1500RPM earlier, at 2500RPM the 16 valve has *twice* the torque of the 8 valve.
Peak torque on the 8 valve was 155ft/lb, on the 16 valve 179ft/lb. From 3500 to 8300 I have over 85% of maximum torque on the 16 valve, on the 8 valve torque hits 85% of maximum at 4400 and drops below again at around 7200. Thats why I changed to 16 valve..
Here is a real example from a big rolling road day at Walkers workshop on Sunday 15th, two engines, one an 8 Valve 'Kent' Crossflow, 1780cc, fully worked big valve head, 296 degree cam 40 Webers and 4->1 exhaust, the other a 16V Rover K series 1788cc, standard head, standard plenum, 268 degree cams, 4-2-1 exhaust.
Both engines made around 146BHP (xflow 145, K series 147)
The following figures are torque in ft/lbsRPM 8v 16v
1500 45 56
2000 68 91
2500 101 130
3000 112 133
3500 112 129
4000 111 132
4500 126 140
5000 129 136
5500 130 134
6000 126 126
6500 112 118
7000 99 108
Speaks for itself... at 1500 RPM the 16v has 24% more torque, at 2500 the 16v has 29% more torque, at 4000 18% more. These are real life engines, no theory here, in order to match the 16 valves output the 8 valve has to use a lot more cam and a big valve head fully reworked. This has worsened its low down torque. The output from the 8 valve is considered very good for a road engine too.
A naturally aspirated 1788 K series 16 valve engine fully reworked (by me) was on the dyno today at Walkers Workshop and made 251BHP and 163ft/lb of torque (90ft/lb per litre). See it in CCC magazine next month, show me an 8 valve aspirated 1800cc engine with those sort of power and torque figures and I'll show you my testicles on a silver salver.
Dave"
1500 45 56
2000 68 91
2500 101 130
3000 112 133
3500 112 129
4000 111 132
4500 126 140
5000 129 136
5500 130 134
6000 126 126
6500 112 118
7000 99 108
Dave"
