Crankcase breather systems
    Mine doesn't have factory heads. I just need something quick and easy. When I get back from os in July I'm probabaly going to pull the engine out anyway. Thinking about L76 goodness.
    2004 Nissan El Grand rape van
    2007 Suzuki SX4 - Ski Mule
    2005 WR250
    + 2 trailers and a caravan.
    I finance the RMS
      The traditional RWD OHC 4cyl Ovlov motors have a hole in the side of the block where the fuel-pump was operated from an auxhiliary shaft on (rare/early) carby versions. Most cars have a pretty big blanking-plate over it, the hole is probably a good 1.5cm in diameter; and replacing the blanking-plate with a hose to a catch-can is apparently a really good cheap'n'easy breather.
      Are there similar holes already in your engine?
        There is a blanking plate over where the mechanical fuel pump used to be but its right down low.
        2005 WR250
        I finance the RMS
          http://www.circletrack.com/readerste...ips/index.html
          Came across this by accident. Nothing that hasn't been discussed here, but noteworthy is the report that it fixed the issue.
          John McKenzie
