turbo chargers ....
    crack, thgat pick has saved you from almost certain banning I think as of late ancient thread bumpage.
      crack: I appluade you sir, for being a fuckin funny cunt.
        it's a series of tubes, just like the internets.
          aluminum tubes like the ones that found in iraq
            Originally posted by ZENNON View Post
            err - normal atmospheric pressure is about 1 bar
            so if turbo is making 6psi that is on top of the natural 1 bar
            so yeah about 20psi absolute
            not sure how that help you to understand how turbo's work tho..
            Yeah its actually closer to 21psi (14.7 psi) was just thinking off the top of my head was the 20 psi.
            I have never really looked in to turbo's just the NA side of it.
            Royalpurple Oils
              I see where he is coming from - in the intake system while the engine is running the pressure in a NA car is always negative compare to atmspheric - if it wasn't air wouldn't flow.
              Theoretically you could have a turbo making 0psi boost through the system I.e just bringing the negative pressure up to atmospheric and still getting some power benefit out of it.
              In some old cars they had a vacuum gauge that showed this negative pressure throughout the inlet (usually marketed as an economy meter) If you could use a turbo to decrease the amount of vacuum then effectively you would be increasing the airflow to the engine and getting a power increase.
              Originally posted by tandy ass
              Got a 97 cielo for free (I think i got ripped off)
                I sense a great idea coming. One that no-one had ever thought of before....
                  I am just saying that a turbo doesn't have to be providing positive pressure when compared to atmospheric pressure to be doing something useful.
                    Except in real life it does to overcome the drag it puts on the system
                      I agree and for next to no extra cost / size etc, boost pressure is available via that method anyway.
                        Originally posted by psssi98 View Post
                        I don't know how they work but the fucken whoosh makes the powerz and getz tha bitchez.
                        wait ... what ... when did they start doing this?
                        obviously only works if you have a t04z
                          whenever i see that "ULEH" on the intercooler it makes me giggle
                            14psi is roughly atmospheric pressure , so 8 psi boost is 8 psi over normal atmo pressure , not 14+8.
                            But most of it your right.. natural atmo sucks air in , so there is a slight vacuum ( air is lazy ) in the manifold on the intake stroke.
                            ʎɐqǝ uo pɹɐoqʎǝʞ ɐ ʎnq ı ǝɯıʇ ʇsɐן ǝɥʇ sı sıɥʇ
                            The Burquas arent better at hungry jacks!
                              Unless the throttle valve is closed enough, in which case the vacuum in the inlet manifold can be quite high.
                              Originally posted by bugle
                              The non GTS's were gay
                                http://www.autospeed.com/cms/A_0237/article.html
                                should help
                                is there a shop i can buy that uleh stencil?
