thats a awesome graph!! so how much rpm is 146 km/h
What will go wrong, part 568240 - Dyno time..
Royalpurple OilsOriginally posted by Carroll SmithThe price of Man in motion is the occasional collision.
Peak power is just under 6,000rpm. Something is restricting power going any higher in the revs, either the cams are too small for the bigger capacity or the stock exhaust manifold is crap. Nothing will be changed at this point in time, just want to finish off the little bits and have some fun! (assuming it doesn't nuke itself with nitrous...)
good job Jamie !!!
you going to be out this weekend coming (4th May) for the Nirimba TAFE state motorkhana ??~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
RNJ Fabrication
Design-Machining-Welding
RNJfabrication@yahoo.com
04 0737 0736
well if you have your 2S license i could use a nav for the rallysprint of the hills on the 21st June if you want to come up to hampton.
i think that will be the next event i manage to get to now.~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
RNJ Fabrication
04 0737 0736
James, give me a week or so to work out the timing, it may be possible, I just need to make sure my will and funeral arrangements are in place beforehand :D
Muz, 900kg with the cage and circuit safety gear, 50-60kg less in drag trim. Got a plan to take more weight out if it but it won't happen for a while yet.
Spent the night on the dyno sorting out the nitrous jetting, couldn't go as much as we wanted as it was bloody cold and I don't have a heater for the nitrous yet. Bottle pressure was very low so we had to stay on the conservative side of the mixture knowing that we will have another 200psi in the bottle when it is ready. The good part is nothing broke!
All of the carb tuning is now finished, nitrous will be fine tuned after I get the heater in and working. I'm bloody happy with the way it has turned out especially given the amount of weird crap that had to be sorted. Cold starts are now bloody easy, hot starts even easier. Idle is god and it is very eager to rev. The last five power runs over a 3 day period were all within 0.7hp of each other, I don't think it could realistically be any more consistent.
That place you went to sounds pretty good, they managed to diagnose it all pretty successfully. I should take the Skyline there when we're readyJapanese Nostalgic Car - Dedicated to classic japanese cars
AnusL, see post #45 and #53
Would definetly recomend you take the Skyline there. A friend came along tonight to see how it was going, he hadn't seen the car since before it went there and was impressed with the difference. His comments started when the car started without any hassle which is a lot different to the way it was!
I didn't get a decent nitrous run on video, but you can tell the sound difference if ou listen to one of the other runs and then this one:
http://www.youtube.com/watch?v=XCpLI0951_Q
bottle blanket FTMFW!!!!Royalpurple OilsOriginally posted by Carroll SmithThe price of Man in motion is the occasional collision.
