So i built a trailer
    4.5 M (14.7 feet) x 180 (6 feet)
    Not sure if flex is good. i thought a bit of bracing might have to be used but wasn't sure.
    More pics
    that is all
    RNJ Fabrication
    Design-Machining-Welding
    RNJfabrication@yahoo.com
    04 0737 0736
      Looks so big until the Corona is on there and then it looks small!
        Originally posted by SLO78U View Post
        3 - i'll build the door next weekend i'm working Danny.
        Quoted so you cant back out...
          damn thats some nice work! what did you use to cut all the plate?
            someone else !!!!
            i'm trying to find the RTA rules and can't find them anywhere.
            i had a copy that i used when i designed the trailer but now that i need to go through and do a final check i can't find it. searched and found nothing.
            can someone who has it send it through or post up a link. just need to double check about lights and markers before i go making up light brackets.
            thanks
            James
            RNJ Fabrication
            04 0737 0736
              With the handbrake are they proper cable clamps and not just shitty ubolts ?
              if it was me i would throw another 2 per side to ensure the cable is help nice and tight flipping them upside down si it was up down up then throw a shitty ubolt on to measure slippage with, massive over kill but you get that being a rigger.
              Also another thing that shits me is people that use a big chain and a $2 shackle to hold it on with. people dont seem to look at load ratings of shit. most stuff with a load rating provided its in a good condition will not break till about 5 times the safe working limit thous stretching can happen
                http://www.infrastructure.gov.au/roa...pdf/vsb_01.pdf
                found the link. if you plan on building a trailer read this first !!!
                RNJ Fabrication
                04 0737 0736
                  Which bit did you stuff up on??
                  www.vsport.com.au
                    To tie the trailer together better, you might want to consider adding a low side rail to the sides and front. That will reduce the flex and stiffen it up considerably. As it has springs, I'd be trying to reduce the flex as much as possible as car trailers have a habit of shaking themselves to bits if not solid enough.
                      That's what i was thinking CT, just some 20x20 RHS with a whole stack of diagonals.
                      i stuffed up the rules a bit, i thought the rear overhang was 3.7m. but it has to be the lesser of 3.7m/same as the 'front loading space'.
                      the rear overhang is 600mm longer than the 'front loading space'
                      tyres are aroun 600mm(ish)
                      so i'll make a tyre rack at the front, increases the 'front loading space' which makes the rear part of the trailer legal. which means no cutting.
                      however i will have to put some bracing on it because the trailer just went from 4.5M to 5.1M.......
                      RNJ Fabrication
                      04 0737 0736
                        If you are interested, try fit a supercheap winch to the front of the car trailor. It was more than enough to roll the car up in a minute or two.
                        Jason Broadhurst
                          Looks awesome mate! What were the expensive bits?
                          Did ya get a nigga ta hook ya hook wif sum steel? Difference in price between retail a special price for someone with buying power is pretty nuts.
                            thats a great job
                            you should sell those dude
                              Originally posted by stalin View Post
                              thats a great job
                              its not worth it.
                              I built mine about 2 years ago now (thread on here somewhere) and spent 3 full weekends on it and even after cost price from sims metal on the material and finding the cheapest springs & axles in Australia it still cost $2.5k by the time you paint it, blue slip & rego it. And thats assuming you have all the necessary tools available
                              I reckon you then be lucky to get 3 - 3.5k for it. There is easier ways to make money.
                                looks nice and sturdy that one ^
