Build a 3 cyl 1L Twincam Turbo Charade engine, Very strong ,good head and under 2.0L with the Turbo. Not joking you around here, these are a bloody good little engine and your easyest path to U2.0L 300hp.
Best 2 litre engine
FWIW I designed a 940cc turbo engine for one of my cars (1600cc limit) and this is the result. It's only a rough run, but it could be made to go something like that. The rules also limit us to 8500rpm, with the larger 1170cc engine and no rev limit (that right?) you could do much better.Originally posted by profi View Post2 litre N/A engines normally dont have anything under 5000rpm.
See attachment.
FWIW2 - the gearbox I'm using has about a 160 ft-lb limit before it breaks so I gotta use the Motec to control the boost per-gear and per-revs to keep it under control.
The best engine that falls within FIA-CN (little sportscars) but 2 litre class regulations is the Honda F20C. This category makes 260-285bhp from 2 litre.
I note this one because it's almost entirely privateers or independents running in the category so they go straight for the best power for money.
You know they still manufacturer these engines brand new right? Like, you could walk in and buy one tomorrowOriginally posted by 260DET View PostHe wants best in the real world I'd assume, not some multi $ thing from yesteryear :p
You missed the bit in the same quote where I said you could take your pick of a bunch of bmw motorsport engines too. Pick your 3 series and you'll find a hipo 2L motor being raced somewhere.
Besides, they look (and sound) great with slide throttles. :D
Must be buying the V8 pretty cheap then. It will cost you a good 30k to an M12, but like I said, the schnitzer 2L motors made similar amounts of horsepower but are a little cheaper to buy. Neither are just off the shelf engines though are they? 300hp from 2L probably isnt going to be cheap no matter which way you go about it.Originally posted by profi View PostI had a chat about a bmw engine. I could buy a complete V8 supercar engine much cheaper.
Its a Z4 M Coupe Race car. Can walk in and buy one if you have the $$$$.Originally posted by profi View PostWhats the bmw at the top of the meridian website, sports sedan,gt?
http://www.autoblog.com/2006/03/01/g...acing-version/
Dont sound too bad either.
http://www.youtube.com/watch?v=MxI2JlNPWJ0Originally posted by Buford T. JusticeThis happens every time one of these floozies starts poontangin' around with those show folk fags.
By my calcs, 12a exceeds 2 litre limit....2005cc. In the past, have been a couple of single rotors running in SS, with no great success - state level, when the multiplier was 1.8. Other alternative, 10a, good luck finding parts!
Bike bitzas wouldn't be allowed as it has to derived from a production car....2500 minimum quantity from memory.
Supertourers, from the few people I've spoken to, have said the 300hp+ was mostly fantasy even with all the destroking/head/block re-engineering carried out....unless the engine dynos here are magically more conservative.
Yea, funny because the non mivec twin turbo motor has same powers.Originally posted by ahabthearab View PostThats factory ratings innit?
From my experience Japanese use Very small Horses when they make such claimsMad Cunt
A 12a should comply, i have head about a 1% leaniency rule making it legal. But dont know if this is true.Originally posted by gxxr View PostBy my calcs, 12a exceeds 2 litre limit....2005cc. In the past, have been a couple of single rotors running in SS, with no great success - state level, when the multiplier was 1.8. Other alternative, 10a, good luck finding parts!
Im starting to lean towards a turbo engine 3 cylinder daihatsu engine doesnt sound to badProfi
Im putting one in a mini at the moment. Made 170hp@wheels on 15psi with a small tdo4 turbo. There are a few websites around the world for them, just search gtti in google.Originally posted by profi View PostWhat are these Daihatsu engines? Do you know anything else about them.
72 Mini (4EFTE) 13.8@106mph WSID
New Project CB80 Mini
