Originally posted by Falchoon
View Post
Ford Oz to produce turbo 4-cyl engine for Falcon
Its a performance motor, will result in the same comparison that people are making re thirsty small capacity high po motors.Originally posted by Falchoon View PostWhy not use the Ovlov 5 cyl turbo as per Focus XR5T?
If you use a motor which was designed from the ground up to be turbocharged and economic - there isn't any reason why it wouldn't work out (VW motors being an example).Parramatta Eels, 2009 Premiership rightful winners.
This 4cyl Falcon doesn't sound like it'd be any worse, in principle, than the 150Nm@15600rpm 3L direct-injected V6 that Holden are planning on using.
It'll be interesting which one wins the marketing battle though; "it's 4cyl not 6cyl" ... "but it's turbo and turbo is always thirsty" ...Soft roaders represent an excellent compromise between the needs of the hardcore 4x4 user and the convenience of a city hatchback. Its clear to see why they have become so popular in todays society.
Will definitely be exempt.Originally posted by Skitza View PostWas just going to say... What will the P Platers do? Bet Ford will rally the Gumbyment and let them make an exception. I think someone else did this as well, VW with the Diesel Golf ? or am I way off?
Amongst others they're allowed to drive the lo-po turbo/blown petrol cars eg. some VWs, 200Kompressors, Saabs, Volvos etc. Kicker is each P plate driver must apply for an exemption for the vehicle they wish to drive. The legislation must have been thoroughly reviewed for effective operation prior to implementation.
The definition of "effective operation", in these cases, is "did it allow the employment of a bunch of useless public-servants with nothing to do".Originally posted by excelboy View PostThe legislation must have been thoroughly reviewed for effective operation prior to implementation.
It did, therefore it was effective.Soft roaders represent an excellent compromise between the needs of the hardcore 4x4 user and the convenience of a city hatchback. Its clear to see why they have become so popular in todays society.
The disease is contageous.
BMW 1 and 3 series to offer three-cylinder engines from 2012 onwards.
it would be cool if it went into a light weight rwd platform maybe the ford equivilant to the pontiac solstice, but i dont see much of a market for a big turbs 4 bangerOriginally posted by BabalouieGeez we're a bunch of softcocks...we have a 911 and we're obsessing over non-functional ducts and indicator colours
Really? VW passat is largish... and it comes with a 2L turbo. The Skoda Superb is near Falcon sized and is pushed around by a 1.8L turbo.Originally posted by vet 180 View Postit would be cool if it went into a light weight rwd platform maybe the ford equivilant to the pontiac solstice, but i dont see much of a market for a big turbs 4 banger
My VW Passat being an earlier model is a 1.8 litre turbo pushing along a medium size sedan. It can be a zippy car with the manual and is usually pretty good on fuel but boy can you notice when you get 4 adults in the car and try to drive off boost :oh: Also under certain conditions it uses more fuel then my modded Monaro...
More info...
http://www.smh.com.au/drive/motor-ne...0918-fuan.html
Currently it's putting out 147kW.
Surely the diesel donk mentioned for the Territory will slot straight into the Falcon & make infinite more sense than a 2.0T petrol?!
S'pose we shall see what these ecoboost units perform like in real world situations in Eu/US before they arrive here - with the torque figure coming in as low as that article mentioned no doubt the performance should be adequate to move the barge, the question will be what the economy hit is.XLII - 101010 - 2AOriginally posted by Jimat the last place there was a few ocassions where you'd go into the toilets (office environment mind you) and there'd be a length of brown cable in front of the shitter. A big chocolate slug looking up at you.
Don't forget that you have to spool the turbo up to get the down-low torque; about the only time you can ever achieve the lowest-rpm torque-figures turbo car manufacturers claim is on highways going up long hills in high-gear. Lag always stops you from getting boost that low in the rev-range 'round town.Originally posted by THE ASH View PostS'pose we shall see what these ecoboost units perform like in real world situations in Eu/US before they arrive here - with the torque figure coming in as low as that article mentioned no doubt the performance should be adequate to move the barge
So it might be capable of going OK, but I suspect it's just ab out has to feel a bit doggy.Soft roaders represent an excellent compromise between the needs of the hardcore 4x4 user and the convenience of a city hatchback. Its clear to see why they have become so popular in todays society.
