Ford Oz to produce turbo 4-cyl engine for Falcon
    Might be a little far of yet, but sounds interesting.
    With gasoline and diesel prices in North America around US$2.12 to $2.35 a gallon – half the levels of a year ago – urgency to develop high-performance diesel engines has softened, especially as OEMs face an almost unprecedented financial plight. Ford’s product plans, for example, see its 4.4-litre V8 diesel for the F-150 delayed until 2013.
    As many OEMs lack diesel engines for light-duty trucks and sports utility vehicles, pressure will grow for high performance gasoline engines with the power and torque, fuel economy and clean emissions of a diesel, especially with demands to raise CAFE standards. This raises the question of whether compacted graphite iron (CGI) will find use for cylinder blocks of North American V8 gasoline engines.
    Under a shroud of secrecy, Ford, AVL and Ethanol Boosting Systems (EBS) of Cambridge, Massachusetts, working with the US Department of Energy, are testing an engine called Bobcat. Five new ‘ethanol boost’, twin-fuel turbocharged engines have been built and each variably blends gasoline and ethanol to produce diesel-like performance.
    Bobcat engines run on E85, a mix of 15% gasoline and 85% ethanol and with such technology, a 5-litre engine could potentially produce diesel-like 500bhp and 750lbft torque. Bobcat uses a secretly-sourced CGI cylinder block which helps the engines cope with stress levels associated with high combustion pressures. It is believed Ford aims to use Bobcat in flex-fuel vehicles running on gasoline, ethanol or any combination of the two.
    EBS claims its technology gives a 30-35% efficiency gain at one third of the cost of a gasoline electric hybrid, but this technology also requires a strengthened engine structure such as might be found with CGI. The CGI engine structure is essential to deal with 150bar peak cylinder pressures. Increased bolt diameters are likewise essential.
    Fitted to a Ford F-series truck, a spark ignition engine optimised for E85 could give 15-20% fuel economy gains compared with a production gasoline engine and would meet at least ULEV ll/Tier ll Bin 5 requirements. E85 is used only as required at high loads to avoid knock, leaving the efficiency of gasoline improved by using a high compression ratio downsized engine.
    The technology requires special cylinder heads, including variable cam timing, twin turbochargers with waste gates, special port injection of both fuels, and two high-pressure pumps driven by inlet camshafts. Also, EBS requires a second fuel tank or a separate tank-in-a-tank. In a car, this second tank for E85 could be replenished (5 gallons per 5,000 miles) at the dealer – like the urea refill for diesel SCR. A production vehicle is slated for 2012. EBS is also believed to be working with Mack Trucks/Volvo AB for heavy-duty vehicle applications.
    Ricardo also is working on ‘optimised’ spark ignition engines with diesel-like efficiency. Ricardo’s system, Ethanol Boosted Direct Injection, uses a 3.2-litre GM gasoline engine to give the equivalent 660lbft peak torque of GM’s Duramax 6.6-litre diesel. However, the Ricardo engine uses a grey iron block with a special cradle to support the crankshaft. The engine has bespoke aluminium cylinder heads.
    And
    According to Ford’s SAE presentation, an experimental 3.5-liter GTDI EcoBoost engine modified with E85 direct injection and gasoline port fuel injection run on a dynamometer achieved a BMEP score of 305 psi (27 bar), which translates to approximately 553 pounds-feet of torque and 316-hp at 3,000 rpm (flat torque curve from 1,500 to 3,000 rpm). The experimental engine was limited by the engine block’s ability to handle higher compression ratios. In comparison, a standard GTDI EcoBoost engine on a dyno was rated at 17 bar, which translates to approximately 350 pounds-feet of torque and 300-hp at 4,500 rpm (flat torque curve from 1,500 to 4,500 rpm).
      liquid injection lpg coons are out next year. about time...
        Torque delivery in a modern turbo petrol car has never been a problem. Some have peak torque figures from 1500rpm. Its just people seem to want to always compare a turbo diesel with a normally aspirated petrol engine.
          liquid lpg turbo coons?
            That would be fairly pro
              you are fairly pro
                lpg and turbo i doubt it, performance and cost savings usually do not go together, would just be the bread and butter versions as far as i know.
                however now that hsv have liquid injection lpg cars, ford/fpv may follow suit?
                  yeah let's hope so
                  i doubt ford will wanna like back and take it like a bitch
                    you like back
                      Bet its a turbo diesel.
                      Han, Enter the Dragon
                        fuck this has fail written all over it, in capital letters, with a courier tag to fail room in fail building that doesn't exist so it'll get returned to the offices of Fail McFail on the underwater Fail Boat that has sunk at the bottom of Fail Lake that used to be the main tourist attraction of Fail Land until it failed.
                        "And on we raced, hurling watchdogs against doorsteps, curling them under our burning tires like collars under a flat-iron. Death, domesticated, met me at every turn..."
                        -- Marinetti
                        Zoom and Extreme Performance production editor. Check out the new Zoom WEBSITE!
                        2006 BF XR6 ute [daily]
                        1981 XD 4V 351, Toploader, 9in [project]
                          What makes people at Ford think LPG adoption will go up magically?
                          (TM - AVENGE)
                            Australia has ample gas reserves...even with selling so much to China. This means that Australia has a reliable fuel for the next 60+ years at current consumption - petrol will become a problem in half this time frame.
                            E85 is a distraction...it takes a huge amount of water to produce ethanol and it's not like we have a lot spare in Aust.
                            Biodiesel might be a good future fuel.
                            Sir John Monash
                              Probably won't .. but would if petrol was $2/L...
                              High petrol prices and the corresponding dive in sales was the only thing that got thinking of developing alternatives. By the time they hit market, unless petrol is once again "expensive", nobody will give a crap.. until the next time they scream like stuck pigs when it reaches the old high, and then some.
                              your former friendly cambodian dictator
                                i think that if you want to move people to LPG you have to provide more incentives... EU govts. provide much more attractive incentives
                                and i think manufacturers have a fair way to go to make it easier on buyers... the EU has kits for most cars... even Corollas and that shit
