Originally posted by obsessive
View Post
Under 2 litre ipra kar options
Much difficulty in using that engine?"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower." - Mark Donahue Penske Porsche 917
(TM - AVENGE)
Thinking of building an IPRA mini and punt it around my local hill climb. Looking at the regs, it states you have to use a production block - so, in my case I'd use a 1275 A-Series. Doesn't mention anything about the cylinder head. Anyone know if this is free to change to something else? Have my eyes on a BMW bike head conversion.
From Matt Read?Originally posted by QABB View PostThinking of building an IPRA mini and punt it around my local hill climb. Looking at the regs, it states you have to use a production block - so, in my case I'd use a 1275 A-Series. Doesn't mention anything about the cylinder head. Anyone know if this is free to change to something else? Have my eyes on a BMW bike head conversion.The most dangerous risk of all - the risk of spending your life not doing what you want, on the bet you can buy yourself the freedom to do it later. - Randy Komisar.
Yeah, heads are free. There is one in SA which is/was running a bike head.Originally posted by QABB View PostThinking of building an IPRA mini and punt it around my local hill climb. Looking at the regs, it states you have to use a production block - so, in my case I'd use a 1275 A-Series. Doesn't mention anything about the cylinder head. Anyone know if this is free to change to something else? Have my eyes on a BMW bike head conversion.
On that topic is there much about the BMW bike head conversion for minis out there?Chris
Cool. Thanks takai. Full steam ahead then.
These guys are the gurus for BMW heads on A series blocks:
http://www.twinkam.co.uk/shop/catego...aram=cid%3D%26
I've got a K1200RS head lined up which has hotter cams than the run-of-the mill K-series Beemer. Just waned to know if it would be legal under IP regs.
I've also managed to find a short stroke crank for my 1275 which, with my .020 over pistons gives 1115cc and should rev pretty hard. Multiply by 1.7 for a turbo gives 1895cc. Dunno how competitive it will be but should make about 200hp and weigh 550kg.
from that link.. holy yes please..
http://www.twinkam.co.uk/shop/articl...id%3DSCE002%26Originally posted by Walt KowalskiMemes are only detectable by NSA.
FWIW this is the reg you wanted:
THanks for the links too, always wanted to look into the twincam 1275s after having a Supercharged 1275 in the UK.4.1 General: Subject to the limitations contained in 4.2 and 4.3(iii) below, the engine and components directly associated with its function are free. The crankshaft centreline as viewed from above must be parallel to that of the original engine.
4.2 Block:
(i) The block must have the same number of cylinders/rotors and the same configuration as was standard or available as a manufacturers option for that particular model (eg, in line, horizontally opposed).
(ii) The block must be from the same manufacturer (eg, Ford, GMH, Nissan) as the original car.
(iii) The cylinder block must either be:
(iv) (a) derived from an eligible car as detailed in Regulation 1.1 OR
(b) derived from the same family of engines as an eligible car using identical internal dimensions (with differences only in transmission mounting pattern, minor external casting differences etc). The block type must be clearly identifiable, ie, Nissan SR20DE, SR20DET, Holden Family II, Toyota 4AG series etc. The derived block must be identifiable as being from a mass produced vehicle, not exclusively developed for sporting evolution models produced for homologation purposes in small numbers for competition use only. CAMS will be the final arbiter in determining the eligibility of a block.
(v) CAMS reserves the right to add any engine block at its discretion. Engine blocks included in this definition are: Nissan FJ20.Chris
so who owns BMC these days? last i saw they were absorbed by chrysler in the 60/70s?? would that mean you could use a PT cruiser motor or something?Originally posted by Rdyno70ynu has to be the most retarded cunt here. "Help me please" me "you need to remove your head" him "fuck off cunt I'm to lazy fuck off out of my thread you told me to do something I don't want to do so you're a cunt fuck off can some one please tell me an easier way???"Originally posted by TripperIts a tight battle between you and rogercordia for the most retarded member on here, thou i think you have it by 5 window licks
in that case, you could still use a PT cruiser engine, or go some sort of wacky peugeot motorOriginally posted by Rdyno70ynu has to be the most retarded cunt here. "Help me please" me "you need to remove your head" him "fuck off cunt I'm to lazy fuck off out of my thread you told me to do something I don't want to do so you're a cunt fuck off can some one please tell me an easier way???"Originally posted by TripperIts a tight battle between you and rogercordia for the most retarded member on here, thou i think you have it by 5 window licks
Yand it's also turbo injected.eah, heads are free. There is one in SA which is/was running a bike head.
I can put you in touch with the guy if you have any queries.Originally Posted by Tut
