I REALLY NEED YOUR HELP cunts
    rorge i've had the same problem mate, every cunt is shut til the 11th
    Originally posted by 350stato
    100% agree with Shifty
      But it'll be ok! Old mate will have come through, Ed can pick up the axle at sparrows fart, take the rims to get fitted and then sit in the sun for 5+ hours for scrutineering... Or wait till i come home and line up because they scutineer until freakin 11pm!! :D
      '10 Forester Diesel 6Spd - Slow and sensible
      '93 SWB Pajero - Slow but scary
      '89 MX5 B6-T - Scary not slow
        Originally posted by Ed View Post
        Dad (engineer) says you cant heat the axel up, it wont be hardened steel or even high carbon steel and will press back into shape easily enough without heat. Anyone who suggests putting heat on it doesnt know what theyre talking about.
        He reckons the bearings will be fine because the force required to straighten it shouldnt be all that huge. He also reckons the bearings can be removed and reinstalled without damaging them, if thats neccessary.
        People intentionally put straight axles in the press to bend them to gain camber all the time, its not great for compnent life but it works.
        PM me for more info
          Hey Rorge, u gonna detail the Lantra for me?
          /csh Racing
            Originally posted by Glenno View Post
            Fuck people intentionally put them in the press to bend them to gain camber all the time.
            The housing, not the axles.
              Sorry misread the post as housing not axles.
              PM me for more info
                You definitely have faith in your fellow man.
                  Just picked the axle up. Its bent under the bearings so they didnt bother straightening it, just machined the face of the plate a bit. It should run straight now but Im a little worried about the studs not being concentric as the center of the outer end of the shaft may have moved.
                  I dont really have any way to test it other than fitting it and seeing how it goes.
                  Wheels are at the tyre place getting some new shoes. With a bit of luck we'll be pre-nats pimping the streets of canberra tonight.
                    It will be fine. relax. Check the nuts after you drive for ten minutes.
