Nub 2J + Single Turbo Question
    Hey mate, did you still need to use a hoist? sorry had to run off to a wedding last time you stopped in.
    2JZ KE20 Corolla 7.97 @ 178
    SR20DET Gemini 8.70 @ 157
    http://www.oke020.com
      http://www.atpturbo.com/mm5/merchant...Category_Code=
        Shipping Weight: 8.00 pounds
        I wonder what the standard one is?
        I JUST SHARPENED A PENCIL IN MY BUM AND NOW I NEED A BANDAID
          got the .82 or 1.06, a .62 on a 2j will be constipated and gay
          1JZ747 Racing
          8.37 et PB
          169 mph PB
            Originally posted by jasonp1977 View Post
            And my new 6boost manifold, even with stock studs! :p
            i call photoshop
            1JZ747 Racing
            8.37 et PB
            169 mph PB
              Fixed?????????????????????
                I used a T3 open collector ebay manifold on a mate/customers car and it took ou the GT35's turbine from the grape sized blobs of stainless hanging inside the manifold out of sight. If you use one of these you should inspect it with a bore scope first. It's only the open collector manifolds that seem to suffer from this, the twin entry manifolds are much less crowded around the collector and you can see the offending areas.
                We replaced the GT35 with a 6boost and 1.00 TO4Z and the car ran an 11.3 @ 118mph last night. Makes 440hp atw through a high stalled auto.
                Jew Sex, I might be able to hook you up with a .82 housing for the proboost GT35. I also have a Tial .82 V band housing but that isn't going to suit any manifolds.
                If you wanted to be a real tightarse you could make a Y adaptor off the std manifold. It's still make 400hp no worries.
                One of the cars we built made 360hp atw at 13psi with a 1.06 GT35. This was before it had any FCD at all. Went on to make 450 with 550's and SAFC.
                Conversely, I have another customer with a Supra that we fitted a home made shit manifold too with a Precision T66 turbo with a very small exhaust housing on it. No matter what I tried I could not get more than 350hp atw out of it. 2JZ's do not like or need tight exhaust housings. It is not a POS Nissan engine.
                  Mate you need to give up on modifying the car if you're crying about spending >$4K. Going faster costs money especially if you have to pay for parts and fitting twice because the el cheapo option lunched your engine/turbo/whatever.
                    I'm all for your plan as per the PM. Just reply RE: the specifics and ill get the ball moving and everyone can be happy there is 1 less set of twins rolling around.
                    Eat a dick. I'm a stingy prick, not an idiot.
                    Past
                    74 260z - MOBY
                    00 WRX - JARVIS
                    93 Rz Supra - SOUP
                    05 Golf GTI
                    07 350z Track
                    73 240z - Red Car
                    13 BRZ
                    04 Liberty GT
                    10 ISF
                    Current
                    91 SW20 MR2
                      I reckon youll need a bigger wastegate than 38mm, 50mm would be best. Those tiny 38mm things are for 4cyl shitboxes. The only thing I would not be a tight arse with is the wastegate.
                      PS. Lol@ Jew Sex
                        PS. Lol@ Jew Sex
                        Yup going 50mm.
                        Past
                        74 260z - MOBY
                        00 WRX - JARVIS
                        93 Rz Supra - SOUP
                        05 Golf GTI
                        07 350z Track
                        73 240z - Red Car
                        13 BRZ
                        04 Liberty GT
                        10 ISF
                        Current
                        91 SW20 MR2
                          Just jap/ebay 600x300x100 works just fine in the tonner, 480rwhp & intake temps only 15 odd deg above ambient.
                          What I'd do:
                          6Boost manifold
                          2nd hand XR6 GT35r
                          Ebay cooler & fitting kit
                          Tial gate
                          Bigger injectors
                          Retune
                          +1
                          Big power turbo with shitty flowing manifold won't do you any favours.
                          Originally posted by TRD-RT81
                          would not care as long as when i fucked her my balls did not touch matt damon's
                          Originally posted by MR 1JZ
                          lara bingle is a fucking dropkick slut with a nice set of tits
