What torque settings to reassemble my Simmons with?
    Muz - you sure? i've never seen nyloc nuts on simmons and that includes a brand new pair straight from the factory.
      Originally posted by xwavgas View Post
      Loctite is your friend also.
      Yeah, definitely using Loctite on it whatever torque settings.
      Also these ones seem to be the original bolts/nuts, aged about the same as the rim. Plus the new V4s that a mate got in 2007 had that style of nut, not nyloc or trilocs.
        Originally posted by choppo View Post
        Me too. 8 Alta's.
        Last one Retro did for me had a leak through the silicone....
        How much does Retro charge to take them apart and put them back together?.
        1000HP VT taxi cab
        www.castlehillperformance.com.au
          Originally posted by dhs View Post
          I think those are called Nordloc.. why are they so pricey? we use em at work (in washer form as a pair per nut).
          nord locks are just the washers, they have nothing to do with the nuts
          those nuts are called wizzloc nuts, or just serrated flanged lock nuts.
          as for the torque value for doing the wheels up, i have seen 30 ft/lb thrown around as the correct value for SSR wheels, but even then it would depend on the bolts/nuts used.
          Originally posted by Mr Jones
          Farmer its all about how you cut them up, like a dead hooker jigsaw puzzle.
            We always used the aircraft nylocs but the main point is not to use a mild steel nut.
              Not sure actually, always had inners replaced at the same time and on multiple wheels. Got sick of the cost hence was going to try to do it myself. Problem fixed = bought different wheels
                Not sure of the name of them, they're all metal, self locking nuts - should be readily available at any reasonable fastener place. Seem to be common on all the three piece wheels I've touched...top looks like it's staked.
                There are comprehensive tables for imperial fasteners in shear and tension, coarse and fine thread. After trying to get something on 10x1.25 12.9 grade into aluminium the other week, might have to resort to best guess if there's nothing standard.
                  Is it worth asking the fastener supplier what the recommended torque value is?
                  2010 State Colouring in Champion
                    If you can wait a bit I will dig around in our archive for AS1275-1985 for metric fasteners.
                    It will be 70% of the proof load with lubricated threads.
                      On that subject, does locktite work as a lubricant when torquing bolts? I have seen a few threads arguing that it hinders accurate torque readings vs a properly lubricated thread torqued correctly shouldn't need locktite
                        call them and ask??
                        http://simmonswheel.com.au/
                        i would be rather sad if i took a random answer off an internet forum and my wheels fell apart.
                        EMS Cold Start - starts third time, every time.
                          Would Neales wheels know?
                          They seem to repair alot of wheels
                          30 Gould St
                          South Strathfield NSW 2136
                          (02) 9642 1002
                          MK7 Golf R 11.3@123.9mph. still working at getting into the 10s
                          F80 M3 LCI2 10.78@130mph ( Quickest stock turbo M3 in Oz )
                            +++1
                            You should go by the specific nut/bolt combination you have.
                            Any number you get from a part manufacturer will simply be based on fastener type/size/grade.
                              Yeah, can wait for a bit. Ill pull out the part numbers for those nuts and bolts and find out what grade they really are from Coventries.
                                Molydbenum disulphide grease is actually the best lubricant for tensioning fasteners especially internal engine components, but for something like a wheel assembly that is subject to vibrations, then I would prefer to have an anerobic locking compound on them, as the range of tension is going to be pretty fine for a small M8. but yes a correctly tensioned fastener shouldn't come undone..but then Murphy steps in sometimes.
                                Originally posted by dan View Post
                                call them and ask??
                                I spoke to Simmons some time ago about buying new outers and they really said that they weren't interested some bullshit liability thing,
                                I seriously doubt that they would then provide tension specs for someone, imagine if they gave that info and then you fucked it up and it came apart.
